A/C problem
Old Aug 23, 2012 | 03:41 PM
Skydivemark's Avatar
A/C problem
I'm pretty sure I have a vacuum leak. sometimes when I'm accelerating it quits blowing thru the dash vents and goes to the defroster and if I take my foot off the gas pedal for just a second or 2 it returns. I'm under the belief that the defroster is default when vacuum system doesn't work properly.
Mainly I'm just looking for pointers &/or hints where typical leaks may be. I saw one guy said to look at a line by/behind the battery. I saw a square-ish box about the size of a large sponge there, is that a vacuum accumulator of some type?
Old Aug 23, 2012 | 05:55 PM
Streetglider07's Avatar
What are you driving? I know on my f250 I had the same thing it was caused by a vacuum leak in my auto locking hubs. When I would switch to 4 high the ac would change to the defrost. Fix the leak fixed the swapping If that is not your case you still have a vacuum leak some where
Old Aug 23, 2012 | 10:23 PM
Yes, that's an accumulator back there - but the most common source of leaks are cracked vacuum lines themselves behind the battery. They are small plastic hardlines.
Old Aug 27, 2012 | 02:35 PM
Oops, I'm kinda new here, thought my vehicle type showed up with name. It's a 99 f150 4x4 and the hubs are permanently locked.
