$&@&ing power window 99 f150 problems
Ok so my window regualtor went out and it gets stuck check the tracks. The tracks look ok so I replace my window regulator with a doraman OE solutions regultor well so I spent an hour maybe more putting the new one in couldn't put the last bolt in because there no way to make a bolt fit in the lower right corner and if it's to small it won't bolt so I got it all plugged in and mounted and tested it out it's getting stuck half way then goes down the gets stuck going up and the auto down function doesn't work so WTF Anyone ever do a install and what should I do its a brand frigging new regulator so idk I thought wd-40 but want to ask if it's a good idea before I just do it.
fixed it i just went to my junkyard and bought a 6$ new track put it in and my window works perfect love how the new regulator is so quite the old one sounded like a hydraulic ram thought it would cut my arm off
