F150 shutters when turning from a stop.
Old Jul 25, 2012 | 04:28 PM
Colorado01's Avatar
Question F150 shutters when turning from a stop.
When I take off from a stop (e.g. turning from off-ramp, stoplight) the whole truck shutters a little bit while accelerating. What would cause this to happen?
Old Jul 25, 2012 | 04:53 PM
1997 lariat 4.6's Avatar
when was your transmission last serviced? You may have a misfire.
Old Jul 25, 2012 | 05:07 PM
Richard D's Avatar
I suspect it is the Limited Slip chattering. I would try to either add some of the Ford Friction modifier to the rear end or service the rear end with new fluid and make sure you pout the Friction modifier in.
Old Jul 25, 2012 | 05:11 PM
kingfish51's Avatar
More likely it has never been serviced. Should drain and refill with the proper gear oil (75w140) and make sure friction modifier is added.
Old Jul 25, 2012 | 07:45 PM
melansonbx93's Avatar
Sounds like your rear differential needs to be serviced, but then again we aren't the ones driving it to get a feel of the symptoms to properly diagnose the problem. Is it throwing a code at all? If so, get it scanned and see what they say. I'm not sure but I don't think the rear end chattering would throw a code, but I know for a sure a misfire would.
Post up and let us know so we can help you further.
Old Jul 25, 2012 | 08:02 PM
bassin butch's Avatar
I have the exact same issue: I changed out the diff lube and used new synthetic plus modifier. Trans had a tech flush: I am putting new plugs and boots on next. Mine is very intermittent.
Old Jul 25, 2012 | 08:29 PM
Colorado01's Avatar
It feels like the shuttering is coming from the back of the truck so it's most likely the diff. Also I was walking past the back of the truck today and noticed a little bit of dirt collecting at the bottom of the diff, like it's leaking some, never noticed it before now.
Old Jul 25, 2012 | 10:12 PM
Bluegrass's Avatar
A possiblity is one EMG brake assembly has physically come apart and jambing up.
Jack up the rear with both wheels off , Trans in neutral.
Rotate both directions and not any noises, drag etc.
Good luck.
Old Jul 25, 2012 | 10:32 PM
Colorado01's Avatar
There's also a slight whining sound coming from the back end when accelerating. Would having low diff fluid have anything to do with that?
Old Jul 25, 2012 | 10:54 PM
Richard D's Avatar
Absolutely, I would recommend servicing that rear differential ASAP.
Old Jul 25, 2012 | 11:35 PM
Colorado01's Avatar
Thanks, I'll try to get it in by the end of the week. What's the likely-hood of it locking up with low diff fluid?
Old Jul 26, 2012 | 12:25 AM
Richard D's Avatar
Very possible.
Old Jul 26, 2012 | 09:53 AM
kingfish51's Avatar
And if you have a 4x4, it would not hurt to service the front diff. Doesn't need friction modifier, but gear should be replaced. I believe for the front, Ford recommends 75w90.
Old Jul 27, 2012 | 09:39 AM
Big B's F450's Avatar
my f150 did the same...did the service to it and it got a lil better but the chatter continued...found out mine was the clutch packs...put in new eaton true trac problem solved...just like brand new...
Old Jul 27, 2012 | 06:58 PM
Colorado01's Avatar
Update on the servicing, I forgot to take a picture before I took the lid off. There was some leakage from the very bottom bolt.
Got the cover off
Got the lid all cleaned up and shiny
Got the lid back on and now I'm waiting for the silicone to cure
