My truck is freaking out!!
Old Jun 26, 2012 | 09:54 PM
CentralCali559's Avatar
Its a 2001 F-150 XLT ext cab, 4.2L 2wd The oil pressure isn't going up but i checked the oil and it has pressure. the Check engine soon light just came on. the abs light came on. When I'm at a stop light with the brake pedal depressed and have my turn signal on, the flasher flashes super fast, I get off the brake and step on the gas and I hear the flasher flash normal. I think I can hear something when I'm braking, but can't be sure. I switched out the speedometer to the autometer lunar series back in Dec, truck has been parked since Dec while I was in Afghanistan. It has LED tails don't know if that has anything to do with it.
Old Jun 26, 2012 | 10:16 PM
ParnAZ's Avatar
Post the codes please and yes the LED tails are why ur flashers are going so fast.
Old Jun 26, 2012 | 10:31 PM
I'll grab my tuner and check the codes. When it's parked or I'm not stepping on the brake the LEDs flash like they did with the old taillights.
Old Jun 26, 2012 | 10:38 PM
4.2xl2001's Avatar
I remember seeing the cluster pics on here a while ago. Maybe the connector on the back has issues. I repaired my OEM cluster, just a pin to solder, and removed my gauge needles to clean....it took a long time to get the gauges to read correctly again because putting them back on exactly like they were is a PITA. Had to put the needles back in with the truck running and remembering what the gauge should read at that point.
Old Jun 27, 2012 | 12:16 AM
Duffy1992's Avatar
Fast blinker means brake light out
Old Jun 27, 2012 | 01:41 AM
Or LED's without a resistor module or a flasher made for LED's.
Old Jun 27, 2012 | 11:41 PM
Ok so first time trying to drive at night and I turned the truck on in my driveway and as I turned my lights on, it's died. I tried it 3 times and all the dash lights come on and it dies. Could the aftermarket cluster be causing this??
Old Jun 28, 2012 | 03:26 AM
jbrew's Avatar
Sounds like the battery. They can get all goofy if the battery has a weak cell and having a hard time keeping above 11 volts. It may be hard to tell when it's border-line, without checking it out.. Yea, I'd check the battery -its easy enough to do.
Old Jun 28, 2012 | 09:32 AM
Toyz's Avatar
^^^^X2
Especially since it's been sitting since December
Old Jun 28, 2012 | 11:24 AM
Ok I'll check that. I have a optima yellow top, I took it out and stored it in a dry place.
Old Jun 28, 2012 | 01:42 PM
That is likely the problem - Optimas aren't what they used to be. Take it in and get it charged and tested.
