Transfercase fluid
Old Jun 22, 2012 | 01:32 PM
02FORD4X4's Avatar
Transfercase fluid
Now I know yall are gonna say use the search function, which I did but didnt find whaty I needed. I did however google what Tcase fluid to use in a Borgwarner 4406 and all I found was 2 quarts of Mercron V ATF. Is this correct? Thanks for the help.
Old Jun 22, 2012 | 02:42 PM
Correct.
Old Nov 28, 2014 | 07:23 PM
Draeger's Avatar
What if you put more then 2 quarts in Transfer case, will it hurt anything? make anything not work?
Old Nov 28, 2014 | 08:47 PM
You can't overfill it, it will run out the fill hole.
Old Mar 30, 2015 | 11:02 PM
Cdomino's Avatar
Anyone try Mobile 1 synthetic ATF?
Old Apr 1, 2015 | 12:44 PM
That should work fine.
