Foglight Mod Problem
Old Jun 18, 2012 | 12:35 AM
MistaGavin's Avatar
You guys probably get people asking questions about the FL mod all the time, but I have researched as much as I can handle tonight. Here we go:
I have recently completed the fog light mod, but something isn't working right. I have a 2000 F-150 Lariat with factory autolamps and factory fogs. I have hids in my headlights and for foglights. I did the mod to the switch so I am able to pull it out in parking light mode and I spliced the brown and black/white wires together (2 & 12). My problem is that when I switch my parking lights on my headlights come on too (bad). When I pull the **** out from parking lights my foglights come on (good) and my headlights stay on (bad). I removed the splice, because I thought that I may have messed up the switch, but all positions function normally like it did before the mod. Any ideas why my headlights come on in PL with the splice in place?*
Thanks, Mike
Old Jun 18, 2012 | 12:53 AM
FallenF96's Avatar
Never mind, re-read your post, I over-looked the part about normal op. Sorry bud
Old Jun 18, 2012 | 11:47 PM
MistaGavin's Avatar
Nobody?
Old Jun 19, 2012 | 10:19 AM
Red02FX4's Avatar
Be patient, noob. Incorrect answers could come every second, while correct answers may take just a little time. Hang in there. I'm sure that someone will be around that will solve your issue.
Welcome to the Forum
Old Jun 19, 2012 | 10:35 AM
MGDfan's Avatar
Hey.
So - you followed this: http://www.svtlightnings.com/svt/how...s/foglamps.htm
faithfully and stil have that problem?
Quick check - install original halogen bulbs - and the wiring to stock - and re-test. ( You are using relay harnesses, right, so this should be easy to do - if not, that's not helping you at all).
I suspect yer cheap crappola PnP kit(s), as this mod, done properly, works perfectly.
Good luck ( and I agree with Red - instant gratification should not be expected for free help - folks have priorities - thanks in advance ).
MGD
Old Jun 19, 2012 | 11:44 AM
MistaGavin's Avatar
I will take the hid relay out and pop in the Silverstars I have laying around for my main headlights. I'll report back after work.
Old Jun 19, 2012 | 11:59 PM
MistaGavin's Avatar
No dice guys. Disconnected all aftermarket lighting and just plugged in regular 9007s. Same result, headlights on in parking lamp mode. Double checked and everything works as normal without the splice. Black/white spliced with brown on the 12 slot plug. Any Ideas?
Old Jun 20, 2012 | 01:17 AM
Red02FX4's Avatar
I don't have this mod, so I can't be of any help to ya. BUT, I've been here long enough to know there are some that can help. In my opinion, put your lights to where they work properly, and await a proper response. Again.. be patient. We all have jobs,family and/or other priorities (as MGD said). I'm confident you will get your answer.
Old Jun 20, 2012 | 06:37 AM
MGDfan's Avatar
IF this a Canuckian truck , did you perfrom the additional wire cut required?
That worked for me.
Good luck - after that I dunno...
MGD
Old Jun 20, 2012 | 10:29 AM
MistaGavin's Avatar
No it's not, no DRLs.
Old Jun 23, 2012 | 11:58 PM
MistaGavin's Avatar
Figured it out thanks anyways guys
Old Jun 24, 2012 | 01:59 PM
scootr2200's Avatar
Well, can you report as to how you solved the issue?
Mickey
Old Jun 24, 2012 | 11:28 PM
MistaGavin's Avatar
Had to cut the black/white wire before the splice so that the white/black and brown wires will still connected to the plug. Not sure why I had to do this as it is not Canadian, but a fellow on another forum had the same problem with a US truck and fixed it that way. The instructions on that tutorial are slightly more vague than I would prefer.
Old Mar 31, 2013 | 02:42 PM
Fox Fader's Avatar
Yeah I had the same problem as the OP, which means the wiring instructions on that page are inaccurate. When I find the right info, I'll post it.
Old Mar 31, 2013 | 07:13 PM
ford4life.'s Avatar
Not necessarily some US trucks come with auto headlamps.
