I need professional Help!...
Old May 15, 2012 | 12:55 PM
EHFF ONE FIFTY's Avatar
So.. I know about as much about my 98 f150's 4.6L V8 engine asa monkey.. 1st off i made the mistake of getting the 4.6L so im told?.. I want mine for you know.. maybe cruising along and smoking a couple chevys. or mudding. What are acouple things i can do to improve performance or what should i do?. I have heard 5.6L 4V Swap or 6.8L V10 swap. DOHC.Super/turbocharge. Any suggestions?.. feel like i went all over with this but im just not a fan of my truck not performing to how high i talk **** about chevys. thanks alot!
Old May 15, 2012 | 01:07 PM
Bluegrass's Avatar
Of course the following reply is with respect.
If your not good with mechanics, don't try any involved change.
Look at a and read the thread called 'Starting a V10 swap" and see all the hassle.
You have about two good choices.
1. To have your motor built with updated heads, cams, intake manifold mods and headers that will get you into the 375 to 400 hp range with a 4.6.
2. Super charge a good stock motor.
3A. Have a performance shop do it all because either option should be programmed tuned on a Dyno.
Please bring big wallet.
Goopd luck.
Old May 15, 2012 | 01:10 PM
oldnnew's Avatar
My advice, don't worry about it. If you're going to just cruise around or mudding, that engine will be just fine. As far as smoking Chevy's, it doesn't really matter. Sooner or later you will grow out of your teens or twenties and realize it doesn't really matter...
Old May 15, 2012 | 01:56 PM
1clean42's Avatar
'nuff said.
A good tune will wake the engine up enough to be a little more fun to drive, but a truck's not really built to race anyway. Making it sound good will make it more enjoyable as well.
Old May 15, 2012 | 02:14 PM
jbrew's Avatar
Originally Posted by 1clean42
'nuff said.
A tune won't really do much for the 98 4.6 or 5.4. It will adjust the shift points for a preference tune, but performance wise. Nope.
The 2001 4.6 - That year + can gain from a tune.
The 1999 5.4 - Same, that model year and up.
Old May 15, 2012 | 02:57 PM
str8t six's Avatar
ill help save you alot of time, money, frustration.
sell it and buy a lightning
/thread
Old May 15, 2012 | 03:03 PM
Alex_4.2L's Avatar
I find my 4.6 to be quite peppy. Of course I'm used to driving slow trucks. It's not a car dude. My girlfriends 4 cylinder G6 can smoke a lot of race trucks. If you want a race car buy one or a lightning. Other than that it takes off from a stop just as fast as everyone else. Even capable of getting a ticket. Side note: racing is for the track not the street.
Old May 15, 2012 | 03:18 PM
5.6L is a Nissan Titan engine
Old May 15, 2012 | 04:18 PM
1997 lariat 4.6's Avatar
you can do a 4.6 4v swap, im still researching, and searching for money, more money, and parts. Just the heads will give that NPI 4.6 about a 100 hp boost. then if you supercharge it, ohhhh baby!
Old May 15, 2012 | 09:50 PM
wilderthing's Avatar
The 4.6 is a good, reliable, pretty good on gas engine.
I find it peppy as well. Very suitable for muddin, some towin, haulin, etc
My 4.6 has 375 000 kms.
Yes the 5.4 has more power- but do you need it just for cruzin? no. Do you need it for muddin? debatable. Do you just want more power? Absolutely, who doesn't.
And I agree with everyone else- buy a lightning or be prepared to empty your wallet.
What I would do to your current truck is for looks, function and performance on and off road:
Mild lift with bigger tires
Lockers
Taller gears
better sounding and flowing exhaust
Do a tune up- could wake up your truck a bit if it hasn't been done in a while.
clean maf- same as above
Gotts mod
Drive and enjoy
Enjoy
