35s or 37s?
Old Apr 29, 2012 | 02:03 PM
DerrickT113's Avatar
35s or 37s?
Hey guys. I have a 03 f150 supercrew 5.4L 2wd and I am putting the fabtech 7.5" suspension lift on it soon. I know fabtech says to use 35s with this lift, but which would look better? 35s or 37s? Also, if I go 37s do I need the 1.5" daystar spacers? I plan on putting on a set of 17x9 mickey Thompson classic lock rims with the nitto terra grappler tires. I hear that the 35s are the best to go, and that 37s require to much trimming. I just want to know which ones will look better on the truck, thanks.
Old Apr 29, 2012 | 05:16 PM
Buxton91's Avatar
You won't be able to fit the 37's unless you do HEAVY trimming.
Old Apr 29, 2012 | 05:40 PM
pizzaman711's Avatar
Not only would you need the spacer, you'd also need aftermarket control arms to run the spacer properly, and a body lift to clear 37's. You need a bare minimum of 10ish inches to clear them and even then you'd have to do some trimming.
Old Apr 29, 2012 | 09:28 PM
Floridian4x4's Avatar
I have a 6 inch Fabtech lift with 35s and I would think with a 7.5 inch lift you could fit 37s in there, but I am betting the guys above me have more experience...
Old Apr 29, 2012 | 10:09 PM
Judging by your username your 4x4. So you having 6" is the equivalent of him having about 8-8.5ish.
