Fuel Pump Problem??
Old Mar 23, 2012 | 04:16 PM
MiniMo163's Avatar
Fuel Pump Problem??
A couple of months ago, I parked my truck and before I cut it off, it sputtered and died. I was low on gas and figured it ran out since I was parked on an incline. Let the truck set for about 30 minute and came back out and it started right up. Worked fine up until last week. I cut the truck off and went to restart immediately and it just cranked and would not start. Once again, left it for about 10 minutes, came back out and it started fine. Today I drove it for about an hour, parked it and came back out to start about 15 minutes later. It started, sputtered and cut off. Wouldn't restart. I let it set for 15 minutes and it started up fine. I drove it for about 30 minutes and it just died while I was going down the road, tried to restart and it would just crank but not start. I let it set for about 15 minutes again. Started up fine and off I went. Drove for 20 minutes and it died again and would not start. Once again, I let it set for 10- 15 minutes and it started fine. Got home about 20 minutes later and it was still running fine. I cut it off and restarted it without any problems.
I checked the relays, none are blown. I had the spark plugs and one of the COPs replaced 6 months ago.
It is a 2000 F150 4.6L w/ an automatic
Thanks for any help!!!
Old Mar 23, 2012 | 06:35 PM
When was the last time you changed the fuel filter? What brand spark plugs did you use?
Old Mar 23, 2012 | 09:28 PM
MiniMo163's Avatar
Fuel filter was 15-20K miles ago and used motorcraft plugs and coil.
Old Mar 24, 2012 | 03:38 PM
MiniMo163's Avatar
Any thoughts? Thanks!
Old Mar 25, 2012 | 12:38 PM
fairlaner's Avatar
I had the same symptoms on my '99. I replaced the fuel pump and haven't had a problem since.
Old Mar 25, 2012 | 01:28 PM
jethat's Avatar
I would change the filter again and if it still did it I'd spring for a pump. I change my filter about every 10k miles..
Old Mar 25, 2012 | 01:44 PM
You could throw a fuel pressure gauge on it to confirm that it's a lack of fuel issue.
Old Mar 25, 2012 | 02:19 PM
c1t1d1's Avatar
either bad fuel pump or check value is bad.
Old Mar 25, 2012 | 07:58 PM
Volfandt's Avatar
Oribable fuel pump
Your symptoms sound similar to the ones I had on my 98 w/a 4.6.
Mine didn't set any codes.
I just recently replaced the fuel pump & filter but haven't run it snough yet to tell.
It has improved starting and strangely the engine doesn't ping when cold now either. Both are definitely improvements.
Performance seems the same but I'm hopeing for alittle better fuel economy, we'll see.
Good luck
Dave
Old Mar 27, 2012 | 12:30 PM
MiniMo163's Avatar
Took it to the shop this morning, they said it was either the fuel pump or the ignition control module. Haven't heard back from them, but I will post the results when I know. Thanks for the help!
Old Mar 28, 2012 | 07:07 AM
JCR 56's Avatar
A 2000 4.6 doesn't have an ignition control module to my knowledge. They do have crank and cam position sensors.
Old Mar 28, 2012 | 11:41 PM
MiniMo163's Avatar
They drove it for two days and couldn't get it to act up, so they didn't charge me anything for the diagnostic test and sent it home. Once it breaks again, ill take it back. Thanks for the input!
