Wiper transmission
Wiper transmission
Wiper arm broke (no it is not stripped). Ive removed the cowl piece and found the broken section of plastic and a torn apart bushing. From my searching around today, looks like a dealer only part as the whole transmission. Some auto parts were carrying the replacement bushings but nobody had the whole assembly or the piece I need. So, looks like I have to replace the whole linkage. Just making sure any of you might know somewhere other than the junk yard or dealer ($125) to get one of these.
http://www.ebay.com/itm/New-OEM-00-0...#ht_1587wt_275
Or you can buy the bushings and fix it.
http://www.amazon.com/Dorman-49451-W...ar=1&carId=002
I know they make replacement white plastic ball caps but I need the rubber bushing where the wiper mounts to the control arm. Which I don't see a replacement for. Was told I need a new assembly. Ive thought about buying used, but used is going to be wore out. It would be like buying used shocks, probably better to buy new.
