PATS won't go into program mode for fob
Old Jan 14, 2012 | 10:20 PM
rayjayfl's Avatar
I purchased a 2002 F150 XLT, only came with one key and one fob, I purchased a second key and fob from ford dealer (OUCH). The guy at the counter gave me instructions to program the fob to save a few bucks. I followed the instructions, same as in the owners manual on off 8 times etc but can not get the locks to cycle to program the fobs. I have searched several forums with different ways to do it, ie; door open door closed seatbelt fastened seatbelt unfastened headlights on and off, kneel in the seat cough 3 times while turning the key and wiggling my ears (kidding) but still can not get it to go into program mode. anyone have any suggestions? reboot the PATS system maybe? if so how to?
Any help or suggestions would be greatly appreciated.
Ray
Old Jan 14, 2012 | 10:55 PM
lltoolj's Avatar
Im not quite sure but im sure someone can help
Old Jan 14, 2012 | 11:01 PM
Pockets's Avatar
LMFAO the description made me laugh
I don't have experience with the fobs but the keys worked fine with me
Sorry really liked the kneel on seat cough 3 times etc. hahah
Old Jan 14, 2012 | 11:16 PM
My01SCrew's Avatar
Pretty sure you can't do anything with only one key programed to the truck. Think the stealership has to program the other key before you can program anything.
Pats Technical Article if you haven't read it yet.
Old Jan 14, 2012 | 11:19 PM
rayjayfl's Avatar
Thanks,
the instructions are very straight forward but reading forums all day I have heard some odd variations and tried them all, like most electronic equipment i thought a reboot mught do the trick but I don't know how and what the risks are such as losing the one fob I have that does work or wosre yet having a no starter.
Old Jan 14, 2012 | 11:22 PM
rayjayfl's Avatar
I have no key problems. I have 2 working keys, now I want 2 working fobs (remotes) I have one that works but from what I understand you program both / all at the same time
Old Jan 14, 2012 | 11:27 PM
My01SCrew's Avatar
I only have one fob myself so I don't know exactly. This thread reminds me, I need to find my other key.
Old Jan 14, 2012 | 11:33 PM
rayjayfl's Avatar
In that tech article you linked to, section 4 is what I am trying to do but I can not get past the first step off/ on 8 times to go into program mode.
Old Jan 15, 2012 | 09:19 AM
projectSHO89's Avatar
The remote entry system has nothing to do with the PATS system.
If the CSM won't go into program mode, there's likely to be some fault associated specifically with it or one of its input signals.
Old Jan 23, 2012 | 12:35 AM
BlackFerret's Avatar
A couple of suggestions:
First make sure that you unlock the doors with the lock controls on the door not the key fob (Doors should be closed).
Second, following those instructions you really have to be quick when turning the key from on to off and back again 8 times in 10 seconds, make sure that the key is turned completely to the off and on positions when doing this and make sure that you end with the key in the on position. As a side note the key has to be turned 8 cycles (Key from on to off and back to on being one cycle), not just 8 times.
Third, this shouldn't make a difference (It didn't when I programmed my old and new remotes when i ordered replacements), but is the key an original key that came with the truck from the factory?
When I programed my remotes it took three of four times to get the truck into programming mode, I was not fast enough with turning the key 8 cycles.
Good luck!!
Old Feb 14, 2012 | 07:08 PM
rayjayfl's Avatar
PROBLEM SOLVED!
I had all but given up since even the dealer could not get it to work (no charge) I moved on to another little problem, my overdrive switch did not work, checked the fuses and found a blown 5 amp fuse, replaced the fuse and overdrive switch works so just for the hell of it I did the on/off 8 times thing and Bingo the doors locked confirming program mode, programmed 2 remotes with no problem.
Old Feb 15, 2012 | 03:20 PM
Fuse F29 supplies switched operating power to the CSM.
Old Nov 12, 2012 | 05:31 PM
msstatedawg's Avatar
Re: PROBLEM SOLVED!
Thanks so much for this, rayjay. I, too, had a switch blown. Replaced it and then was finally able to program my fob. Dealership did not know what to do.
Originally Posted by rayjayfl
PROBLEM SOLVED!
Old Mar 29, 2018 | 04:44 PM
E.Rubio's Avatar
Ray Jay is a life saver
PROBLEM SOLVED!
I did have a blown fuse and thanks to you I got mine working.
Old Aug 8, 2020 | 11:05 AM
MDB007's Avatar
Big Thanks
Man you are the Bomb! My overdrive has been out as well since i got my 04 Heritage last year and thought it was the switch. Sure enough the fuse was blown and switch works now. just did the program and it worked on the first try! Thanks so much for this tip!
Bill
