Lets just say...Dual turbo 5.4?
Old Jan 14, 2012 | 01:22 AM
Smitha6's Avatar
Let's juuuust say...that I wanna put Dual Turbos on my 03 F150 KR 5.4L....
Stay with me here lol...
What would I have to do? Like to the engine, transmission, etc.?
I'm really not sure...at all...but I know I ain't gonna just be able to throw them on a stock motor.
Old Jan 14, 2012 | 01:24 AM
Smitha6's Avatar
Old Jan 14, 2012 | 03:38 AM
nathan3306's Avatar
I hope you have some money. You can check out STS turbo.
Old Jan 14, 2012 | 01:52 PM
Toyz's Avatar
It would require a full build. Forging the bottom end, new pistons, oil pump, heads worked, turbo's, intercooler system, exhaust system, fuel system and a ton of miscellaneous piping, wiring....custom tune, dyno runs etc..
I would estimate something like this being in the 10k+ range. Once a project like this is started, it is a never ending money pit.
You can go supercharged or lightning swap for half that and be more reliable, fuel efficient.
Old Jan 14, 2012 | 01:59 PM
str8t six's Avatar
^^^pretty much all that
Old Jan 14, 2012 | 11:44 PM
BOOMER2011's Avatar
where are you going to get dual turbos???? for the price of dual turbos you could do supercharger........ More power that way anyway.
Old Jan 14, 2012 | 11:46 PM
scootr2200's Avatar
Your best bet is to search the Lightning forums (http://www.nloc.net/) and see how the boys over there build their vehicles to handle the high horse power.
Mickey
Old Jan 14, 2012 | 11:50 PM
Two threads merged. One thread per subject, please.
Old Jan 15, 2012 | 02:31 AM
Buxton91's Avatar
As stated before, an L swap would be much more efficient and reasonably cost worthy.
Old Jan 15, 2012 | 02:52 PM
rch10007's Avatar
Could you please explain how you get more power that way?
Old Jan 15, 2012 | 03:27 PM
str8t six's Avatar
x2, turbos are more efficient.
Old Jan 15, 2012 | 10:29 PM
Raptor05121's Avatar
twin turbos make MUCH more power than a S/C
Old Jan 16, 2012 | 07:55 AM
Midnightride42's Avatar
Why dual turbos? search the forums for remote/rear mount turbo. A single turbo will more than likely give you enouph power.
From what I read you can run 7psi with no issues.
Upgrade the injectors, fuel pump, get a tune, and build your own turbo system(turbo, wastegate, oil lines, intake/charge piping, scanvenger pump, blow off valve).
If you can do the fab work yourself, Looks like it can be done under $1500.
If you want more power, then as stated above you would want to build the motor.
