Misses bad during hard acceleration
Old Jan 3, 2012 | 09:18 AM
Tommy Mack's Avatar
My '02 F-150 4.6L with 211k miles on it started missing real bad the other day. I changed the fuel filter, removed and cleaned the throttle body, egr ports and IAC valve and changed the pcv valve. Now it has a little miss at idle but the real problem is when I get into the gas hard, it misses and stutters bad! Any idea what that could be?
Old Jan 3, 2012 | 09:22 AM
Toyz's Avatar
How many miles on the plugs, coil packs and wires? Or cop's? Is the CEL light on?
99% of the time your misfires are a result of a fouled plug, failed ignition source or lack of fuel.
Old Jan 3, 2012 | 09:29 AM
Tommy Mack's Avatar
CEL was on prior to recent work. 171/174 and an egr code(don't remember the number). Plugs were changed about 12k miles ago. Plug wires are original and COPs are original.
Old Jan 3, 2012 | 10:28 AM
BLUE20004X4's Avatar
If the C.O.P's are originals, one or more is f-d. That being the case, I'd replace all of them. I had a VERY similar prob, it was the #3 again.
Old Jan 3, 2012 | 10:49 AM
Tommy Mack's Avatar
Wouldn't it be giving a code again if one is bad?
Old Jan 3, 2012 | 10:52 AM
Takeda's Avatar
It has plug wires, and COPs? What kind of plugs did you install when they were changed?
Old Jan 3, 2012 | 01:29 PM
Tommy Mack's Avatar
No wires just coil on plugs. Ford Motorcraft plugs were put it.
Old Jan 3, 2012 | 01:37 PM
4.2xl2001's Avatar
were the plugs gapped to spec.?
Old Jan 3, 2012 | 01:59 PM
Nope, the 2 times mine did it, never a code. The wife's Explorer did but I forced it out on the freeway with a code reader in hand. When mine did it, the one in question was visually obvious.
Old Jan 3, 2012 | 03:27 PM
Tommy Mack's Avatar
Yep, plugs were properly gapped.
Is it a must to go back with Ford cops or are the aftermarkets just as good?
Old Jan 3, 2012 | 04:11 PM
bigredpei's Avatar
MAF... Mass Air Flow Sensor. Try looking into that.
Old Jan 3, 2012 | 04:44 PM
Tommy Mack's Avatar
It looked a little dirty and I cleaned it off with electrical contact spray. The wire does not appear to be damaged.
Old Jan 3, 2012 | 10:33 PM
Tommy Mack's Avatar
So.......that's it??? That's all the advice I'm going to get on here?
Old Jan 4, 2012 | 02:51 AM
jgger's Avatar
Check the boots on the cops for cracks/tears/holes. Also check the plug wells for moisture, and make sure the connectors on the cops are all in tight.
Old Jan 4, 2012 | 03:03 AM
jgger's Avatar
With a post like that..............maybe.
