Coil Spring Spacer
Old Dec 27, 2011 | 02:23 PM
LiftedF1Fiddy's Avatar
Coil Spring Spacer
I recently put a 6.5" lift on with 35's and i'm having some rubbing in the front end. I found these, http://www.ebay.com/itm/2-FRONT-LIFT...#ht_2807wt_805
Can I install these with aftermarket springs? And will it stop the tire rubbing? The springs are Spingtech if that helps.
Old Dec 27, 2011 | 02:56 PM
BOOMER2011's Avatar
Im guessing 2wd.
you can but if you are running stock upper control arms you will need an aftermarket control arm.
Old Dec 27, 2011 | 04:04 PM
pizzaman711's Avatar
Yea you'll be fine with those, and he already has the control arms he did a springtech lift.
Old Dec 27, 2011 | 04:12 PM
BOOMER2011's Avatar
oh okay sorry lol
Old Dec 27, 2011 | 09:23 PM
Thanks, I was a little worried because the aftermarket shocks looked a little thicker than the stock ones, maybe it was just my eyes playing tricks on me lol.
Old Dec 27, 2011 | 10:13 PM
BOOMER2011's Avatar
my pro comps were thicker than stock, so maybe they are
