pats flashing, no start..ugh
Old Dec 9, 2011 | 08:23 AM
Uncle Jesse's Avatar
Ok, went out to fire the beast up for the morning drive and no start. It turns over fine, but the theft light is blinking, the odometer has dashes instead of numbers. It ran great when I parked it last night. I will have to have it towed to the stealership when I get home for work I guess. Any idea what I am looking at? Thanks! Happy Friday!
Old Dec 9, 2011 | 09:42 AM
4.2xl2001's Avatar
That little bit of info is hard to go on...Is it doing anything else? Sounds like the ECU at this point.
Old Dec 9, 2011 | 10:09 AM
It turns over but no start. Fwiw, I don't have my Gryphon installed right now. Its been out of the truck for 2 months. The theft light blinks....I am at work right now, so I don't have access to it. I tried the extra set of keys, no dice with those either. Its a 4.6 liter, 2002, 150,000 miles. Had the fuel pump replaced 4 months ago...other than that pretty trouble free..all regular maintenance done..
Old Dec 9, 2011 | 10:17 AM
4.2xl2001's Avatar
Have you ever replaced the alternator...particularly the voltage regulator? Did the odometer work OK until you turned it over? That replaced fuel pump is suspect too but it seems like an electrical gremlin...
Old Dec 9, 2011 | 03:35 PM
Nope, alternator and voltage regulator are all original...the odo has been working fine, I really can't remember what it was doing first thing this morning...will try to get more info this evening
Old Dec 9, 2011 | 06:16 PM
When i first get in the truck and put the key in, the odometer reads numbers..after I try and start it, the odometer goes to dashes...anyone got ideas? I just disconnected the battery..going to let it sit for 30 minutes..
Old Dec 9, 2011 | 06:46 PM
Bluegrass's Avatar
Try this. Turn on the key to run position and let it there for several minutes and see if it flashes a two digit code.
If yes what is it.
Old Dec 9, 2011 | 08:01 PM
Awe crap..well the tow truck just picked it up. I am going out of town for the weekend...happy anniversary to me!
Old Dec 9, 2011 | 09:19 PM
Thanks guys for the hints though. I tried searching during my off time today at work, but we have plans to go out of town this weekend. I just didn't have the time to chase this down...
Old Dec 9, 2011 | 11:19 PM
BrianD's Avatar
Check fuse #30. My truck did the same thing a few weeks ago and it was the #30 and a coil pack.
Old Dec 10, 2011 | 12:32 AM
I was just about to say, check the fuses... I read of one today. Had nearly the same symptoms except it would start but issues with the dash readout
Old Dec 10, 2011 | 09:39 AM
I did check the fuses last night, they were all ok. I talked to the dealership this morning, they said it started up fine first thing this morning (of course), so they pulled it into the service port and shut it off. Then it would not start again. Let it sit for awhile and tried it again, then it did start. Pulled it into the work bay to look at it..so I will see what they come up with.
Old Dec 12, 2011 | 12:56 PM
Well dealership called me back this morning...it seems the pcm has taken a dump. Need a new pcm, new keys and some other goodies...yippee. Merry frigin Christmas to me...ah well...
Old Dec 12, 2011 | 01:34 PM
What's the damage... 1200?
Old Dec 13, 2011 | 02:52 PM
Right about that..maybe a little more with taxes. Glad I had right about that in savings...time to start over!
