Steel or Plastic?
Old Nov 10, 2011 | 07:03 PM
wutagoalie's Avatar
Steel or Plastic?
Does anyone know off hand on the 99 4.6L if the fuel tanks are steel or plastic?
Old Nov 10, 2011 | 08:01 PM
Toyz's Avatar
steel
Old Nov 10, 2011 | 08:03 PM
kp02-150's Avatar
got a magnet?
Old Nov 10, 2011 | 08:47 PM
wutagoalie's Avatar
Thanks, I have a gas leak, hav'nt had a chance to look under yet. im not sure if its the sending unit or just a fuel line or the tank , Im sure its the tank though, i only smell gas when i fill up over half a tank. If i have a small pin hole, does anyone know of a good product of epoxy or something similar to seal it up?
Old Nov 10, 2011 | 09:15 PM
RShad's Avatar
It might be starting to rust out at the end of the filler neck where it meets the tank. Mine has been getting pretty bad now and it is due for a changing. Only leaks when I get gas. The gas sits in a indentation on the top of the tank. Next time you get gas look under by the tank to see if you can see any gas leaking on the ground. This is a known problem with these trucks. Mine is a 97 F150.
Ron
Old Nov 10, 2011 | 10:41 PM
BOOMER2011's Avatar
you know there was a recall on the 1998 and 1999 f150 fuel tanks. i got mine replaced for free.
Old Nov 10, 2011 | 11:15 PM
RShad's Avatar
Was it only on the 98 and 99's? I have a 97 and am the original owner from new and I was never contacted about a new gas tank. Just the straps.
Old Nov 11, 2011 | 12:51 AM
BOOMER2011's Avatar
i think 97-03 and its the straps causing rust and leaky tanks
Old Nov 11, 2011 | 05:24 PM
To the OP - have you had the strap recall done yet?
Old Nov 11, 2011 | 08:35 PM
wutagoalie's Avatar
How long ago was this recall?
Old Nov 11, 2011 | 08:36 PM
wutagoalie's Avatar
I just had it done this week. They never said anything about a tank recall???
Old Nov 12, 2011 | 07:17 AM
If the strap recall repair CAUSED the leak, you may be able to get Ford to replace the tank.
Old Nov 20, 2011 | 11:20 AM
wutagoalie's Avatar
I tried to force it on them when i took it for the recall, told them that when my tank was hanging from the fuel straps that rusted away, i started to smell fuel after that. They told me i have some corrosion on the tank and its a small pinhole not caused by the recall.
Does anyone know where in ontario,canada is the best or cheapest place to pick up a tank? I checked with Napa auto parts they want $210.00, is that about right?
Old Nov 20, 2011 | 11:39 AM
atr04screw's Avatar
You could check the junkyard, but since your in Ontario, they are all probably just as corroded. I haven't ever priced gas tanks, but $210 sounds pretty good.
Old Nov 20, 2011 | 12:03 PM
jethat's Avatar
Rock auto has them starting at $134+ shipping that could get expensive being oversized and all..
