12-volt accessory cover spring
Old Sep 3, 2011 | 09:47 PM
vicikid's Avatar
The door that covers the extra 12-volt accessory plugs has a spring that holds it open and closed. I managed to pop the spring off and can't figure out how to get it back on. Any ideas on where I can find a picture / schematic / instructions on how to replace the spring ?
Thanks,
Walter
Old Sep 4, 2011 | 12:44 AM
Wraith413's Avatar
There is another "hinge" like protrusion on the left arm that one side of the spring goes into. On the mounting arm coming off the panel, look for a tiny hole that the other side on the spring goes into.
Old Sep 6, 2011 | 09:21 PM
vicikid's Avatar
Thanks... found the hinge point and the hole. Having trouble figuring out where the other part of the spring sits to get it to hold the door open or closed.
Old Sep 7, 2011 | 10:17 PM
Wraith413's Avatar
When I replace that whole panel in my truck last weekend, I couldn't find a hole for the other side of the spring on the mounting arm on the new panel. It's a very small hole, barely bigger than the spring wire. Use a flashlight and a inspection mirror to help find it. It's about halfway on the panel mounting arm.
