Pillar Gauges suggestions
Old Aug 30, 2011 | 07:40 PM
MitchF150's Avatar
yep... He now checks the oil in ALL of 'his' and 'her' vehicles on a regular basis! No more seized up motors since then!
Mitch
Old Aug 30, 2011 | 08:23 PM
shifty_85's Avatar
a while back i got my gauges threw glow shift 134 dollars for the pod and 3 gauges of my choice with sending units. and i can change them into 7 diff colors or have them fast rotate or slow rotate. only prob i had was in the winter i revd it up to see how high i could get the oil press went to 115psi and never came back down...12 dollars later its working fine.
Old Aug 30, 2011 | 09:35 PM
camopaint0707's Avatar
Vacuum is nice to help keep your foot off the throttle. I have trans temp, afr, and vacuum.
Old Aug 30, 2011 | 09:47 PM
wookie13's Avatar
I was wanting to add one pillar gauage to my 02. I was wanting to do a tranny temp. Does anybody make a mount that keeps the OE grab handle? All the ones that I've seen all loose the handle.
Old Aug 31, 2011 | 07:46 PM
shifty_85's Avatar
yeah if you want a pillar mount your handle has to go....if it doesnt were are the gauges gonna go???
Old Sep 2, 2011 | 12:09 AM
fairlaner's Avatar
I believe Autometer makes a single gauge pod which mounts to the A-pillar (you retain the original a-pillar cover and grab handle). I have no idea how clean they look when mounted.
Other options for a single gauge are a steering column pod, or mounting the gauge in the cover which surrounds the steering column (just right of the steering column).
Old Sep 3, 2011 | 01:56 AM
NickArellano97's Avatar
Originally Posted by Galaxy
Mitch...one comment about your feedback on a oil presure gauge. I respectfully disagree. I'll sum it up with a story. I once blew the filter mount off my Mustang one day (that's a separate story...completely my fault and not a reason to fear remote oil filters). The first funny indication I noticed was rapidly and quickly fluxtuating oil presure...tell tale signs of loss of quantity. I didn't sexid guess anything...I immediate shut her down. Next I noticed the trail of oil on the road behind me which I did not notice before hand. Had I not had a gauge that day, odds are extremely likely I would have kept driving until the noise and what-not was apparent to make me shut it down, and in that case you would be correct in that the damage would have been done. But due to the gauge, it bought me SEVERAL critical seconds that day and no doubt saved me my motor. Just food for thought, not baggin on ya at all; but you know that!!
that also happened to me today. when i breaked going faster than 50mph my guage did the exact same thing. I checked the oil level it was fine until 3 hrs later when i checked it again and it went down. when i changed the oil only two quarts of oil came out. took the sending unit out and cleaned it and tightened it to specs. my guess is it burned up the oil because i didnt have any leaks. It saved me from destroying my engine.
Old Sep 7, 2011 | 04:33 PM
bink98xcab's Avatar
tank pressure
FL/FR pressure
RL/RR pressure
Old Sep 7, 2011 | 06:31 PM
You could do a dash pod if you are worried about keeping the handle.
Old Sep 13, 2011 | 02:32 AM
Is there a write up for the oil pressure gauge install?
Old Sep 13, 2011 | 01:33 PM
shifty_85's Avatar
i removed my stock dummy senor alot of people put a T on there so they can have there dummy senor and aftermarket. its on the driver side of the block towards the front
Old Sep 13, 2011 | 01:44 PM
five0merc's Avatar
I suggest running every gauge you can fit!! Here's mine...
That's an old picture. Pre amp mod.
Old Sep 13, 2011 | 08:14 PM
Galaxy's Avatar
It's actually a very recent picture...there are still Legacy jets flying around. I am one of very few, and the only guy in AMC dual certified to fly both AMP and Legacy!
Old Oct 19, 2011 | 07:40 AM
Joethefordguy's Avatar
I want to install a vacuum gauge in my F150. Does anyone have a recommendation for brand, type, etc.?
I prefer a 2 5/8, with good lighting - but i have no clue as to what brands are junk, or which are good. I've seen prices from $15 to well over a $100.
mounting recommendations would be nice as well.
thanks for your time.
jg
Old Oct 19, 2011 | 08:51 AM
cobramarty's Avatar
Boost gauge
Air/Fuel gauge
Inlet Air Temp
But I'm going to be supercharged.
