1998 f150 4x4 xlt I need HELP
Old Aug 21, 2011 | 11:05 PM
jgwc11's Avatar
Exclamation 1998 f150 4x4 xlt I need HELP
My turn signals and hazard lights are not working. I have tried checking all the fuses and replacing any relay that has to do with the flasher including the flasher under the dash by the steering column. I also tilted the wheel all directions and still nothing.
Old Aug 22, 2011 | 12:23 AM
ParnAZ's Avatar
Did u check the rear bulbs themselves? I believe the brake lights, turns, and flashers are the same filament (3 volts?). Running lights are 1.5 volts? The bulbs have two different filaments. Just pull the bulbs and check them. Maybe a surge blew all of them at once? You could also use a fuse checker to see if they are getting power. If the fronts dont work either then its a bad connection w/ one of the fuses. Electrical is so much fun.
Old Aug 22, 2011 | 12:43 AM
Carcrazygts2's Avatar
probably the multifunction switch harness.. I had mine pull the pins out of the connector..
Old Aug 22, 2011 | 06:49 AM
jgwc11's Avatar
Carcrazygts2 what exactly do you do to fix this
Old Aug 23, 2011 | 12:11 PM
ParnAZ's Avatar
Unfortunately you have to take the steering column cover off to check the switch. I had to replace my switch a while back cause I had intermittent lights...Just a random thought you might consider..my fuse box screws came a little loose (under the dash above e-brake) and the fuse came loose and would only work occasionally. While ur using the flashers or blinkers take the cover off the fuse box and push on the box and see if anything clicks. GL
