walmart supertec synthetic
Old Aug 19, 2011 | 12:13 PM
acres90's Avatar
I have a 99 f150 4.6 with 165k. I have always used conventional motor oil. Can I swith to full synthetic?...nothing wrong with her...I could drive from here to NY and back and id feel pretty confident id make it. Just wondering about the oil.
Old Aug 19, 2011 | 12:22 PM
Why change from what is working? I would never do it.
Old Aug 19, 2011 | 12:42 PM
You probably could, but I don't know if I'd chance it with that many miles on it.
If it's not using any oil between changes *AND* you can verify that it's sludge-free, go for it. To verify if it's sludge-free, you would need to pull the valve covers.
Old Aug 19, 2011 | 12:48 PM
acres90's Avatar
Well I did have a po304 code so I pull off the throttle body and the tubes combing from the egr valve were completey blocked with carbon and soot, I cleaned it all up but wonder if the rest of the engine looks like the TB did?
Old Aug 19, 2011 | 12:50 PM
acres90's Avatar
Oh yeah it does use about a quart of oil between changes. It has ever since I bought it 10 years ago.
The two are not related. The TB has no oil sludge in it, t's from fuel.
Old Aug 19, 2011 | 12:56 PM
Agreed....
Old Aug 20, 2011 | 07:43 PM
Carcrazygts2's Avatar
i did the mistake of switching and now have major oil leaks and my engine only has 80k on it...
Old Aug 21, 2011 | 11:42 AM
Gotts2BMe's Avatar
no its not
Old Aug 21, 2011 | 07:05 PM
Labnerd's Avatar
There are several suppliers of Walmarts synthetic oil. Look at the bottom of the bottle at your Walmart. If you see the initials WWP, it's made by Warren and is a Gp III decent oil. If those initials are not on the bottom of the bottle, it's highly likely it's made by Mobil/Exxon. Another decent Gp III oil. But neither are a premium oil and frankly, wear will be a little higher in analysis than a blend. Motorcraft and Pennzoil are producing the best wear metals....for now, anyway.
