Tire clearance with 5 inch RCX and 3 inch body
Old Jul 24, 2011 | 11:10 AM
99-Maroon's Avatar
I just recently put on a 5 inch RCX lift and a 3 inch body lift. i had torsion keys put in already. does anybody know what the biggest size tire i can run is? ive ordered 385/70/16 Toyo Mt's which translates to about a 38/15/16. If the tires dont fit could i add a leaf in the bak and crank my T bars up some to level it out and make em work?
Old Jul 24, 2011 | 12:35 PM
Toyz's Avatar
The stock keys would have been more ideal. Aftermarket keys will put your angles beyond where you want them and start eating up ball joints and other ifs components. The 38's should be close to fitting. I ran a 37x13.5 on just a 6" fabtech. But yea, in the end.. you can add an extra leaf in the back and bump the front up a bit to gain another inch or inch and a half. But wouldnt max them out.
Old Jul 24, 2011 | 12:52 PM
99-Maroon's Avatar
Will the 15 inch wide tire clear the stearing knuckle?
Old Jul 24, 2011 | 01:00 PM
99-Maroon's Avatar
will the 15 inch wide tire clear the stearing knuckle
Old Jul 24, 2011 | 03:41 PM
Buxton91's Avatar
That's probably going to be more of a factor based on your wheel specs.
Old Jul 24, 2011 | 09:23 PM
99-Maroon's Avatar
the tires are gona be mounted on 16x10 **** cepek dc-2's. they have 4.5 inch back spacing so would that be enough to clear that knuckle?
