Help need expert advice 2003 f150 super crew
I have a 2003 f150 super crew im having trouble with my vehicle staying turned on while im idle or when i make a turn... When im idle i turn it on then it starts shaking and cuts off but if i turn it on and put it in reverse or drive the vehicle stays on so i drive it fine but when i go make a turn the steering wheel gets real hard & vehicle cuts off- what can this be please help!!!
The two possible problems are the Intake Air Control and/or the power steering has an issue.
The IAC, may not be responding to engine load changes to keep the idle up.
If power steering, the pump maybe putting excessive load on the motor at low rpm when a turn is taken.
One way to check if the power steering or A/C is the cause is to remove the belt for a short test.
Good luck.
Good luck.
