leaking roof
Old Jun 28, 2011 | 04:14 PM
f1504x42000's Avatar
leaking roof
hey, anybody ever have water dripping from the inside roof of the cab? is it geting in there from the brake light? 2000 regular cab rear sliding window. thanks in advance
Old Jun 28, 2011 | 05:48 PM
Johnnyjb's Avatar
yep
happens on pretty much ever rear slidding window
its not the break light its the sealing
u gotta replace it
search threads rear sliding window leak and stuff
Old Jun 29, 2011 | 01:20 AM
fairlaner's Avatar
Here's what I learned when I put a '97 slider in my '99 XL ...
Old Jun 29, 2011 | 10:22 AM
thanks
Old Jul 2, 2011 | 11:39 AM
swampbuck802's Avatar
Had this problem with my 98 Super cab. Would wake up to a soaking wet back seat after a good rainstorm. I removed the 3rd brake light and poured water in that area, then went in the truck to see where the seal was that it was leaking in from, pulled the headliner back, and ran a bead of silicone all the way across the top. 5 dollar fix, and has not leaked again since i did this over six months ago. Hope that helps, or saves you some money/time.
Old Jul 4, 2011 | 08:46 AM
BLUE20004X4's Avatar
I just did this fix on mine, same year and cab as yours. Easy stuff. Gotta replace the butyl seal that is on the window. I used a whole tube of the sealer, it works great. Once the windows out, you'll see why it leaked.
