Fabtech 7.5 inch lift kit
Old Jun 28, 2011 | 12:48 AM
ahun98f-150/2wd's Avatar
Well I have been searching for awhile and I think I'm going to go with the Fabtech 7.5 inch lift kit
My truck is a 2wd and completly stock right now...
I need to know exactly what i would need to do before getting the lift.
What do you guys think??
Old Jun 28, 2011 | 01:03 AM
Lightning Expo's Avatar
Great lift I've never had a problem with it. Just make sure you have proper tools, hopefully access to air tools since it makes it much easier. Easily have it done in a day if your mechanically inclined. 2wd lifts are easy as pie.
Old Jun 28, 2011 | 01:22 AM
Do I have to do anything else to the truck to add the lift like change out parts?
Old Jun 28, 2011 | 01:24 AM
And where about in Orlando are you because I'm in Winter Garden.
Old Jun 28, 2011 | 03:13 AM
GATOR CREW's Avatar
2009 F150online Truck of the Year
I have the same lift and as Lightning Expo said, with the correct tools, it's a pretty easy install
Old Jun 28, 2011 | 01:31 PM
Buxton91's Avatar
Also check your tie rods and ball joints. If they are going out it would be best to replace them while you have everything apart installing the lift.
Old Jun 28, 2011 | 03:26 PM
Altamonte area. Like buxton said you should go ahead and replace all ball joints and tie rods along with possibly changing your end links. Don't forget to flip your sway bar when you do the lift. PM me if you need some advice. If you plan on going bigger at anytime I recommend doestch upper control arms so you can run spacers.
Old Jun 28, 2011 | 10:50 PM
Okay thanks
My friend and his dad and I will be the ones installing it and they have installed lifts a couple of times but this will be my first so im pretty much a noob so the advice is much aprectiated!
Old Jun 28, 2011 | 11:00 PM
Buxton91's Avatar
Fabtech lifts come with pretty detailed instructions and step by step pictures, so you shouldn't have any problems.
Old Jun 30, 2011 | 12:54 PM
Well thats a good thing because I'm gonna need it.
