ep27 relay led flasher
Old Jun 18, 2011 | 08:34 PM
Blue-02-2wd's Avatar
I went out and purchsed this item today to get my led's to quit blinking fast only problem is its to big to replace the original. the bades are the correct size and configuration but the plastic housing is too large. please let me know if any modification was needed (hopefully not scary trimmng inside of the fuse panel)
Old Jun 18, 2011 | 08:40 PM
Raptor05121's Avatar
problem solved
Old Jun 18, 2011 | 08:41 PM
raptor is the man! Once again thanks worked great! only took 10 seconds
Old Jun 18, 2011 | 11:00 PM
Red02FX4's Avatar
.. so what was the solution?
Old Jun 18, 2011 | 11:53 PM
pizzaman711's Avatar
I would like to know the solution as well ha I'm about to order mine
Old Jun 19, 2011 | 05:42 AM
he tried putting it in the fuse box when the flasher relay goes under the dash
Old Jun 19, 2011 | 08:23 AM
its in a covered box by the steer shaft under the dash.
Old Jun 19, 2011 | 10:33 AM
Ah that makes sense ha, I guess it was a good thing I was planning on looking it up in the haynes book before install anyways ha
Old Jun 19, 2011 | 11:23 AM
just turn the flashers on and listen under the dash for the relay you should be able to feel it clicking in the box. take the cover off and the factory relay is blue in color.
