egr line leak
Old Jun 13, 2011 | 05:52 AM
Chuck172's Avatar
egr line leak
I'm trying to locate an engine miss with no check engine code. Noticed a big hole in my egr line.
Can this cause the miss?
Any tips on replacing this line?
2000 f150 4.6
Old Jun 13, 2011 | 12:17 PM
Bluegrass's Avatar
Where is the hole, in the metal pipe?
If yes , you should have a 400 series code set. Failures in this system are montiored everytime the motor is run.
Miss under light load throttle is usually a coil.
The miss can be associated with the EGR operation on a secondary basis.
