Expy bucket swap problem
Old Apr 17, 2011 | 06:09 PM
jmo1112's Avatar
Well, the whole time I've been doing this Expy bucket swap for my bench, I've been waiting for something to go wrong to make it not work, and it finally happened. The 4th hole that I had to tap for the driver's seat (front right) does not line up correctly with the seat bracket. Awesome. Don't know what to do now
Old Apr 17, 2011 | 11:42 PM
Silfox's Avatar
I'm halfway done with thsi myself ( console in, looking for a new seat)
How off is it? Have you tried adjusting the seat tracks? In other vehicles I've had similar problems, and just moved the seat tracks around.
Old Apr 18, 2011 | 12:20 AM
jmo1112's Avatar
Well, I think I can move it over to line up. I think. I don't have the right size wires, so I have to pull it back out anyway in order to run my new ones. I was in a hurry this afternoon when I first saw it didn't go. But when I got home tonight, I just kinda pushed it a little, and it had a little give. It's about two or three inches off, at least. With it just resting there, you can't see the hole through the bracket at all
Old Apr 18, 2011 | 12:35 AM
it should be outboard from the transmission hump. You sure you got the right spot?
Old Apr 18, 2011 | 12:45 AM
jmo1112's Avatar
I'm pretty darn sure. It seems like the logical place for a 4th spot to put a bolt in, it just doesn't match up exactly. There's certainly not another spot close enough for that bracket that would make more sense.
Old Apr 18, 2011 | 01:24 AM
dirtyd88's Avatar
Pictures would help a ton if you could get some
Old Apr 19, 2011 | 08:40 AM
not calling you dumb, but you sure you have the right seat bracket L or R?
Old Apr 19, 2011 | 12:14 PM
jmo1112's Avatar
It's okay... I'd call me dumb.
I got them in. But I definitely had to put the other three bolts in to hold their spot, and then push the bracket about 2 inches over to then put the bolt in. i don't know if it got bent at some point, but it's obvious that it's supposed to fit, it just didn't match up perfectly. The passenger seat DID match perfectly.
Another question. How do you remove the seatbelts? I don't have the one connected to the seats. But the cover at the bottom gets in the way a bit of the seat moving backward. Plus my buckle drops to the floor every time I take it off, so I wanted to replace them anyway. It looks like that cover is riveted on the belt. Do I have to drill that off, or does it have snaps into the floor that I can just pry up?
Oh, and I'll take pics soon
Old Apr 19, 2011 | 09:11 PM
the expy seat belts should be bolted up on the back of the seat frame like right where the seat folds
Old Apr 19, 2011 | 10:01 PM
jmo1112's Avatar
Oh these do not. They're just the seats, no belts attached. I'm still using the original F150 seatbelts. The cover of the over the seatbelt where it attaches to the floor just rubs the power seat control cover (and the manual control cover on the passenger side).
Old Apr 19, 2011 | 11:49 PM
im guessing you have an extended cab then. The female side (buckle) is the part that should be bolted to the inner seat frame side.
this my passenger seat out of the truck (expy frame with modified lightning passenger seat)
http://i21.photobucket.com/albums/b2...r/DSC02117.jpg
Old Apr 20, 2011 | 12:20 AM
jmo1112's Avatar
Ohhhh yeah yeah. On that side it is. I'm talking about on the door side.
Old Apr 20, 2011 | 12:23 AM
jmo1112's Avatar
And yes, I have the extended cab
Old Apr 20, 2011 | 12:44 AM
that cover probably pulls straight up off the base, and then the seatbelt is bolted down with a T45 or T50
oh ya you've got the roof mounted seat belts
here's the written version of ford's instructions, not very helpful pictures either.....
Remove the scuff plate.
Disconnect the front seat safety belt adjustable D-ring.
Pull back the cover.
Using the special tool, remove the bolt and plastic washer.
Using the special tool, remove the front safety belt anchor bolt
Remove the safety belt retractor and pretensioner bolt.
Push in to release the tab and disconnect the safety belt retractor pretensioner electrical connector.
Old Apr 20, 2011 | 01:02 AM
jmo1112's Avatar
I like how they say "special tool" instead of just saying what torx size you need.
I don't really know what a D-ring is, but I'm sure I can figure it out when I get in there.
Good to know I can probably just pull it up from the base. Thanks for the help
