97 f150 guages 4.6 engine
Old Apr 17, 2011 | 03:06 PM
sbracing's Avatar
i installed a different engine from a wreck anyway now my guages are acting up gets upto temp ok holds good oil pressure gas guage ok amps ok then oil pressure pegs out gas goes to nothing amp pegs out turn truck off restart normal again then it all starts over again already changed battery and alternator trucks runs good all the time no codes both trucks were running before no guage proplem
Old Apr 17, 2011 | 03:26 PM
jbrew's Avatar
Learn a little English, then come back and try it again. If you can't even create a proper sentence that all can read, -how did you R&R a engine ?? ~
Old Apr 17, 2011 | 03:39 PM
sbracing's Avatar
What dont you understand????
Old Apr 17, 2011 | 03:55 PM
jbrew's Avatar
Hard to understand without comma's periods.
Do you actually talk like that ?
Well, spellings fair, -capitals in the right places would help a little.
I'm not the greatest either, but at least I can break it up lol.
Old Apr 17, 2011 | 04:00 PM
sbracing's Avatar
Can u help or not
Old Apr 17, 2011 | 05:02 PM
jbrew's Avatar
Can u help or not
No, you would have to pay me to teach you English. Chances are, you couldn't afford it. It may be cheaper for you to have a 9 year old give you a run down on forming sentences. It's a start.
Good Luck.
Old Apr 17, 2011 | 09:44 PM
ONELOWF's Avatar
Good Luck.
Let me translate:
I installed a donor engine in my truck and now my guages are acting up. ECT gauge gets up to temp ok, oil pressure looks good, fuel and amps are ok.
All of a sudden the oil pressure pegs, fuel goes to zero, amps peg.
Restarting the truck, gauges are ok, then the cycle start over again. I've changed the battery and alternator. The trucks runs good all the time with no codes. My truck and the donor were running good with no gauge problems before the swap.
Any help would be appreciated.
Old Apr 17, 2011 | 11:43 PM
lightningx54's Avatar
Good Luck.
Your attitude isn't needed. He's only asking for help.
Old Apr 18, 2011 | 12:24 AM
Buxton91's Avatar
^^^ Sounds like someone hasn't been on the forums enough to know Jbrew. I personally think it's HILARIOUS!!!
Old Apr 18, 2011 | 09:29 PM
yeah he's an @$$hole i get it...
Old Apr 18, 2011 | 09:42 PM
jbrew's Avatar
Originally Posted by ONELOWF
Let me translate:
Holey Crap B, that's incredible! Your like,- Joe Cipher... Good job, I bet your close , if not right on.
On the flip side, I doubt the OP could make heads or tails of it.
Old Apr 18, 2011 | 09:59 PM
jbrew's Avatar
Yes it is, I need it.
If the OP was serious, IMO, he would of been considerate enough to use spell check, periods, comma's, capitals or what not. At least make it legible. He didn't even try.
Old Apr 18, 2011 | 10:00 PM
sbracing's Avatar
Are you going to try and help me or what?
Old Apr 18, 2011 | 10:06 PM
jbrew's Avatar
Yea okay, you go get it, - just stay away from mine.
Old Apr 18, 2011 | 10:29 PM
sbracing's Avatar
Thanks for the help everbody needs an assh--- trying to help you probably dont no **** about it anyway
