Turn signal problem
Old Apr 12, 2011 | 07:37 PM
Derek1845's Avatar
Turn signal problem
Turn signals quit working recently on my 02 Screw, hazzards still work though so I picked up a new signal relay(blue) from my nearby dealer. After I installed the new relay I still got the same noise and no signals. Kind of at a sticking point now, any thoughts or suggestions?
Old Apr 12, 2011 | 08:04 PM
dirtyd88's Avatar
I can't remember if the hazards and blinkers are on different fuses or not...try checking that maybe?
Old Apr 12, 2011 | 09:42 PM
Raptor05121's Avatar
Check your fuses.
Did both sides quit working? Are they hyperflashing or just not coming on at all?
Old Apr 12, 2011 | 11:04 PM
31 YNOT's Avatar
Did you check the blinker fluid?
Old Apr 13, 2011 | 10:01 AM
fordordie1's Avatar
stuff is expensive as heck...specially if u got them turn sigs on your mirrors...
Old Apr 13, 2011 | 07:15 PM
compwrench's Avatar
Mine are going out too
Well, they are out now. My hazards work as well as the brake lamps, said to be all on the same fuse. When I move the lever either way the flasher clicks once. This tells me the switch might be ok. I've read there may be a broken wire in the tilt column that breaks due to tilting the wheel all the way down, my wife drives like that so there may be something to this. Any Ideas?
