Yellowish fluid leaking
Old Apr 12, 2011 | 03:37 PM
Johnnyjb's Avatar
I got a yellow fluid leaking from passenger side by the front wheel?
It's odorless yellow
4.6l engine 2wd
Old Apr 12, 2011 | 04:03 PM
jbrew's Avatar
Would that be coolant be chance ?
Old Apr 12, 2011 | 04:18 PM
pizzaman711's Avatar
Sounds like coolant
Old Apr 12, 2011 | 04:25 PM
Johnnyjb's Avatar
I put water in my coolant
Y tanks on driver side
Old Apr 12, 2011 | 04:30 PM
Well pull out the rubber wheel well then and look up on the side of the core support. There's some lines that are attached to the outside check to see if they're leaking
Old Apr 12, 2011 | 07:51 PM
Toyz's Avatar
Could be refrigerant. Systems came with a greenish yellow dye to help detect leaks. Would be on the passenger side. But I think it was only visibly yellow if an ultraviolet light was used to see it.
Old Apr 12, 2011 | 09:43 PM
Raptor05121's Avatar
Pax side, yellow? That is your R-134a coming off your accumulator.
Old Apr 13, 2011 | 10:55 AM
lightningx54's Avatar
could either be coolant or refrigerant.. the drain for the rad is around there..
Old Apr 13, 2011 | 03:20 PM
MKaybe the dogs have been peeing on your wheel........
Old Apr 13, 2011 | 04:47 PM
