2002 f150 no cruise control no horn
Old Mar 24, 2011 | 10:46 PM
shadow818's Avatar
Im left ####### clueless checked all the fuses getting power up to the horn and cruise control recall fuse. fuses all are good and have voltage going threw them. Any help would be great only thing i can think of is the clock spring
Old Mar 25, 2011 | 09:10 PM
lifted_98f150's Avatar
open your hood. locate the brake master cylinder. if you dont know its on the firewall on the driver side. there is a connector on the end of it. take that connector off. if there is brake fluid in that switch that the connector connects to replace that switch. you can get it from ford for less than 20 bucks. that will fix your problem 9/10 times
Old Mar 26, 2011 | 03:24 PM
fordmatt21's Avatar
First make sure you've had your cruise control recall done. I had the same problem, ended up being either some loose wires behind the dash or the clockspring. I fixed both at the same time so I'm not sure which one actually solved the problem.
Old Apr 19, 2011 | 03:58 PM
shadow818's Avatar
im still cant figure out what it is i will have to recheck all the possibilties again anyone else no what it might be besides the clockspring and the switch any relays or fuses that i should double check
Old Apr 19, 2011 | 04:59 PM
Is the recall done? If not, DO IT. If so, check the harness, there's an inline fuse wrapped up in there. Have you checked the disconnect switch that the harness is connected to for brake fluid leakage?
Old Apr 19, 2011 | 07:18 PM
shadow818's Avatar
the recall has been done i did check the inline fuse its checks out fine i will replace it though just to make sure and i will double check the disconnect switch again no brake fluid leakage but i will double check
Old Apr 19, 2011 | 08:30 PM
jbrew's Avatar
All you do is by-pass the recall harness to check it. Might take two minutes or so. Yea, just disconnect it and plug the vehicle harness back into the Master cylinder. See if anything works. If not, it's not a recall harness problem.
So you checked all relays that have to do with ?
Old Sep 2, 2011 | 06:18 AM
Wraith413's Avatar
Resurrecting an old thread.
I had the same issue on my 97 SCab. Back trace your horn wiring. On the 97, it runs down to the front right bumper bracket. The horn wire was routed in front of the bracket and pulled kind of tight. It then proceeded to chafe through the insulation and would ground out intermittently. Re-route and/or repair the wiring and you should be good to go.
Old Sep 2, 2011 | 11:32 AM
Dinggus's Avatar
What is this recall? When did it come out? I removed my old cruise control because I messed it up with LED's, brought one on eBay and it never worked, no horn or cruise controls, just barely lights up. Guess I bought a recalled harness?
Old Sep 2, 2011 | 02:13 PM
http://lmgtfy.com/?q=ford+cruise+control+recall
Old Sep 3, 2011 | 12:19 AM
Dinggus's Avatar
I know how to use Google, thanks buddy.
So do we just go to the dealership and get a new cruise control switch?
Old Sep 3, 2011 | 01:49 AM
No, you put your VIN into the online recall checker.
http://corporate.ford.com/news-cente...ll-information
If you have any open recalls, schedule an appointment with the dealer.
Old Sep 3, 2011 | 09:37 AM
Dinggus's Avatar
Thank you, ran my VIN and it says no recalls.
Old Sep 3, 2011 | 10:05 AM
check your clock spring for proper operation, and or your ground for the column
Old Apr 30, 2014 | 05:05 PM
jake lasure's Avatar
cruise not wrkin
I have da same problem and wen I do da test my cruise light flashes twice after I press da last button I have done everything I can think of I nd some help thanks.......
