PLEASE HELP! whats in the rear brakes?
Old Mar 21, 2011 | 12:06 PM
PirateSignal's Avatar
I've been doing drum brakes for many years. There is some good advise posted here. The only thing I would add (if it hasn't already been mentioned), is to do one side at a time. That way, if you become confused about how the parts in the kit are installed, you can just go to the other wheel and see how they go.
A friend once took both sides apart at the same time, and I had to go to his house to do one side for him so he had a reference.
Old Mar 21, 2011 | 12:12 PM
jbrew's Avatar
Right, that's what you do and I don't think it was mentioned yet.
Old Mar 21, 2011 | 02:48 PM
MitchF150's Avatar
Here is a pic of the spring kit and what it looked like when it was done.. (Jbrew's is a lot cleaner, that's for sure!).
I got this kit from Ford. It was only around $10 per side if I recall. I got the pads from the local Auto Parts store and also a new set of rotors.. I didn't want to bother with trying to turn the old ones.. Get the spring tool for sure!! Doing one side at a time is a MUST! I've done a lot of rear drums in my day, but having that one intact side always comes in handy!
Mitch
Old Mar 21, 2011 | 02:59 PM
jbrew's Avatar
Old Mar 21, 2011 | 04:35 PM
jimanderson's Avatar
Originally Posted by mcolford
Spend the $10 or less and get the tools, they make spring removal/installation much easier. You may also be able to get these on the loaner tool program at your local autozone/advace auto, etc. if you dont want to buy them, as its not something you will use regularly.
-MColford
I still have my spring tool from when I did my last drum brake job 7 years ago. Thought I had lost the darn thing. It does make a drum brake job go easier.
You may also want to change out the brake cylinder as well. They weren't that expensive and I hate rebuilding the darn things.
Flush all your old brake fluid out!!!!
