Mod thread
Old Nov 5, 2011 | 06:16 PM
  #166
ZW1991's Avatar
http://4wheelonline.com/Products.asp...oductID=154806
so the 2nd option here?.. and it says tire size 32", does that just mean i can fit up to that size?
Old Nov 5, 2011 | 06:29 PM
  #167
Alex_4.2L's Avatar
You could also go with new coil springs for that inch and a half lift. A lot better set up than adding spacers. http://www.canuckmotorsports.com/cat...lift.html#3021
Old Nov 5, 2011 | 06:48 PM
  #168
1998f150wes's Avatar
how do you get all the glue off your moldings cause im still having problems getting it ive buffed them and got an eraser wheel on it and no luck
Old Nov 5, 2011 | 08:43 PM
  #169
ZW1991's Avatar
well it wasnt the best thing but i used some steel wool, like grade 000 i think.. it took off a small amount of clear coat though i couldnt find anything else and it was annoying... and since its slightly angled down, you cant really tell the clear coat is missing
Old Nov 5, 2011 | 08:45 PM
  #170
ZW1991's Avatar
and i think im going with these for my lil lift
http://www.summitracing.com/parts/DYS-KF09105BK/
Old Nov 5, 2011 | 11:39 PM
  #171
pizzaman711's Avatar
That daystar kit should sit you perfect man, just remember your gonna wanna go bigger once you go up a little ha. And I used that orange goo gone to get the leftover stuff glue off from my molding.
Old Nov 6, 2011 | 05:20 PM
  #172
FishGuy5's Avatar
Did you get the headlights that were on your wishlist? How do you like them? Want to switch out my stock ones.
Old Nov 6, 2011 | 08:24 PM
  #173
ZW1991's Avatar
the harley ones? no not yet
Old Nov 6, 2011 | 11:34 PM
  #174
01 gt f150's Avatar
Originally Posted by ZW1991
krammer?
Also known as the 5.0 stroker kit for the 4.6. Different shops have different names for it...My bad if I confused anyone.
Old Nov 7, 2011 | 01:25 AM
  #175
ZW1991's Avatar
oh ok, i tried searching for it and couldnt find anything so i was a little lost haha.. and ive got a plan for just getting a brand new 5.0 engine in bout 3 years or so..
Old Nov 7, 2011 | 11:26 PM
  #176
01 gt f150's Avatar
After I get done with my new suspension I will be saving up for one too.
N/A with bookoo power...gotta love it.
Old Nov 8, 2011 | 12:06 AM
  #177
Buxton91's Avatar
The daystar is a good buy, but a set of new coils would probably suit you better and last a lot longer. When I had the daystar on mine, after about a year it started to sag. I then replaced it with 3" coils and UCA's and let me tell you the handling is 10 times better. I think the 2" springtech coils from canuck motorsports is about $110. A little more expensive, but much better in the long run.
Old Nov 8, 2011 | 08:28 PM
  #178
ZW1991's Avatar
will it produce the same amount of leveling? and is it something fairly easy to install yourself?
Old Nov 16, 2011 | 09:27 AM
  #179
ZW1991's Avatar
ok so ive got a few pics of some new stuff ive done recently..
my wiring harness wasnt working for my HIDs so im not running them through the battery anymore
Vent lights
Washed and waxed
i did some under the hood painting
Old Nov 17, 2011 | 01:30 AM
  #180
woopigsooie's Avatar
you could do the nbs emblems and get blue or white inserts for them.
changing the factory green interior lighting for some blue would look good
