Need help with brake light problem
I am having a problem with both my brake lights and blinkers not working but my third brake light does work. Can anyone point me in the right direction with the issue. thanks
If both corners are out, it would take a simultaneous failure of two circuits to explain the fault. A disconnected or loose connector that is common to both circuits could do it. Odds are better that its a single point of failure, so go with the odds first.
