Where in the world...
Old Feb 22, 2011 | 06:23 PM
blitz_'s Avatar
can I find stainless steel braided brake lines (front and rear) for my 2003 F150 King Ranch 4x4?? It has front and rear disc brakes on it but I can only find them for the front. Im not interested in cheap lines I want ones that will last me for a long time. Thanks for any help in advance!!
Old Feb 22, 2011 | 09:51 PM
zackn's Avatar
Why not get plastic coated lines? Sure stainless steel braided lines look good but the only guys looking under you truck are mechanics and you.
Old Feb 22, 2011 | 10:13 PM
Toyz's Avatar
From what I know, the steel braided lines actually help with better braking and are an upgrade from stock. As the stock lines can stretch, which means less pressure at the calipers.
Old Feb 22, 2011 | 11:10 PM
joh408's Avatar
http://www.klmstore.com/crown-stainl...003-4wd-1.aspx
Old Feb 23, 2011 | 05:53 PM
blitz_'s Avatar
it says a 3 line set but dosent state weither its front or rear. I need a complete set for my front and rear disc brakes.
Old Feb 23, 2011 | 08:00 PM
Red02FX4's Avatar
Subscribing because I would like to know the answer also, as I want the same thing
Old Feb 23, 2011 | 08:05 PM
kp02-150's Avatar
I'm pretty sure you only need three, there's only a single drop to a T that's hardlined to either end in the back.
Old Feb 23, 2011 | 08:07 PM
jbrew's Avatar
That's front and back man lol. Yea, there's just one in the back and two in the front.
EDIT - kp beat me to it.
Old Feb 23, 2011 | 08:16 PM
Red02FX4's Avatar
From that website:
These Replacement Stainless Steel Braided Brake Lines work on the following Ford F150:
1997 to 2003 Toyota Ford F150 4 Wheel Drive.
they put Toyo next to a Ford F150 Bookmarked the page anyways, LOL
Old Feb 23, 2011 | 08:23 PM
jbrew's Avatar
Right , when you apply your brakes, factory lines can bulge/stretch and eventually break down inside. After that, same thing happens , but worse.
Braided lines add an extra barrier that keep that from happening. They won't expand and break down therefore, all the fluid is applied to our twin piston systems.
My 98 stops on a dime, even when loaded down. It was a night and day difference , seriously.
Old Feb 23, 2011 | 08:43 PM
Red02FX4's Avatar
So when I get my Baer slotted/cross drilled rotors I should get a nickel change my brakes are kinda soft so I know between the steel braided lines and upgraded rotors it should be to my liking
Old Feb 23, 2011 | 08:52 PM
jbrew's Avatar
I don't know what your talking about ? What's a nickel change ? What ever man , do what you want
Old Feb 23, 2011 | 09:26 PM
Red02FX4's Avatar
Jbrew.... you said your truck stops on a dime. I want a nickels change, hence the steel braid lines / Baer rotor combo come on man
Old Feb 23, 2011 | 09:39 PM
jbrew's Avatar
Oh, that went over my head doiiiyyy
Old Feb 23, 2011 | 09:45 PM
Red02FX4's Avatar
it's all good tho
