New to site and I need opinions
Old Jan 14, 2011 | 12:57 PM
FAT50RACER's Avatar
GLC:
Thanks for your info on the clutch. I had a feeling OEM was the way to go but thought I'd ask you guys
Old Jan 14, 2011 | 01:00 PM
FAT50RACER's Avatar
Shifty:
I did do some reading on the option of a under drive pulley kit and e fan but I'm going to hold off on that for a while. I want to finish with the shift kit and tuner. Then it's clutch and gears.
Old Jan 14, 2011 | 04:00 PM
shifty_85's Avatar
Gotcha i heard under drive pulleys dont do much for ya.
E-fans are cheap and pretty easy and frees up 10-20 HP i got my fan for 30 bucks.
Old Jan 14, 2011 | 04:10 PM
str8t six's Avatar
if you want to regear. give wayne at diffsonly.com a call for gear pricing. hes a great guy to deal with and beat everyone elses prices for gears.
Old Jan 14, 2011 | 04:25 PM
migdaddy's Avatar
Whered you buy an E fan for $30?!
Old Jan 14, 2011 | 06:20 PM
shifty_85's Avatar
junkyard its even cheaper if i wanted to drive to detroit but didnt feel like going threw. 30 bucks at the junk yard 3 miles away 15-20 bucks at the one 15 miles away.
Old Jan 14, 2011 | 07:28 PM
FAT50RACER's Avatar
Sr8t Six thanks for the info on Wayne just got off the phone with him. Great price and he was very helpful. I will definately be buying from him.
Old Jan 14, 2011 | 07:33 PM
FAT50RACER's Avatar
Shifty:
I guess this is gonna sound dumb but I thought you had to do both underdrive pulley and fan to get that kinda HP. So when you did your e fan kit you just removed the stock fan and leave the pulley on?
Old Jan 15, 2011 | 02:21 AM
shifty_85's Avatar
yeah you just take the big nut off and the fan and clutch come off and you dont have to pull the 4 bolts on the water pump at all.
i used a simple wire from batt with 30amp inline fuse to a switch to the E-fan. and i have an aftermarket temp gauge. when i see the temp get above 200 i flick it on and within 30 secs its back down to 180*
They make those fuse with the temp probes and sell them at autozone and just about anywere but i dont trust those relays heard to many storys about them going bad.
So i used a military rule. Keep it simple stuiped.
Old Jan 15, 2011 | 03:23 PM
In spite of what Shifty says, I would NEVER wire an e-fan direct, that's ghetto. Always use relays and controllers, that's what they are for. Simple in this case can be dangerous.
Old Jan 15, 2011 | 03:33 PM
shifty_85's Avatar
havnt had one prob yet. i tryed a 10amp fuse and kept popin fuses read up on this fan it draws over 15 amps on start up. so i got a 30 amp.
ive had the fan running for over 15 mins before with no probs at all.
yes relays are best but i dont trust them
Old Jan 15, 2011 | 06:09 PM
FAT50RACER's Avatar
Well I will definately have to do some more reading on E-fans.
I just finished my GOTTS mod! Wasn't that difficult at all. I left the silencer in for now. Gonna take her for a spin and she what it runs like.
Old Jan 16, 2011 | 06:12 PM
FAT50RACER's Avatar
Well he truck seems to run a little better between 2500 to 4000 rpms. I am a little conserned though. I drove it today about 200 mile and the truck blew a 0401 code (Exhaust gas recirculation flow insufficient detected). I'm assumimg it has to do with the gotts. I cleared the code with a code reader. Hope it was a fluke and doesn't come back.
Any Ideas guys?
Old Jan 16, 2011 | 06:24 PM
str8t six's Avatar
sounds like a clogged egr valve. i think you can take it off and clean it.
Old Jan 16, 2011 | 08:26 PM
0401's are usually plugged EGR ports in the throttle body. Nothing whatsoever to do with the Gotts mod.
