New Cams, Noisey Lifters ???
Old Jan 12, 2011 | 02:16 PM
Chief Mike's Avatar
I have a 1998 F-150 with a 4.6 v-8. I just the the motor overhauled & install new Comp Cams # 102100. Can someone please explain to me or tell me where I might find info on how to adjust the lifters ( valve lash,pre load what ever you want to call it. ). The lifters really make alot of noise when I start it up cold. They quit down a little bit after the engine warms up. My mechanic says there is no adjustment. My lifters never made a sound till I had the motor overhauled & the cams installed. Thanks Chief Mike.
Old Jan 13, 2011 | 09:22 AM
There is no adjustment. You may need to replace them. Did you use the matching valve springs?
You aren't using a Fram oil filter, are you?
Old Jan 15, 2011 | 04:15 PM
Chief Mike's Avatar
Hey glc, Thanks for your reply. I installed new lifters & the matching springs. Whats the deal with Fram oil filters? (update) I got with my mechanic put my truck up on the lift while it was running. What I thought was a lifter noise seems to possibly be a rattling catalytic converter. Thanks. Chief Mike
Old Jan 16, 2011 | 12:31 AM
Fram filters have an inadequate anti-drainback valve which causes dry starts.
