A lot of things have changed since i have been on here. truck got lifted.
Old Jan 13, 2011 | 02:39 PM
  #61
Buxton91's Avatar
toyz- wow i can't believe i didn't notice that. Those must be the ones that you can add the fake lock rings on.
Old Jan 13, 2011 | 09:21 PM
  #62
Klitch's Avatar
Originally Posted by Toyz
C'mon now. Lugs don't just magically shear off, some kind of force had to be applied, hit a stump.... something? What really happened?
I never sheared lugs on mine with the pony I put down and 35's, locks rear.
Old Jan 13, 2011 | 09:44 PM
  #63
n2muddavid101's Avatar
i have no idea how they came off. it most ,i likely has something with me taking it on the mud all the time like 5 times a week at the least.
Old Jan 13, 2011 | 10:41 PM
  #64
4.2trimble's Avatar
I already told you why they broke, they were over torqued.
Old Jan 13, 2011 | 11:17 PM
  #65
is that the most commen why for them to come off? btw just to ler you guys know i barley know anything about cars/truck but im trying to learn to fix them on my own. its way cheaper also
Old Jan 13, 2011 | 11:54 PM
  #66
MRLSU2U's Avatar
Here's what we're gonna do. I'm gonna buy the truck off of you for $200. You're going to in return go to the local walmart and buy yourself a nice Huffy with the $200. Then you won't have to worry about maintenance or anything. I'll even be nice and give you updates on the truck every now and then.
Old Jan 14, 2011 | 12:14 AM
  #67
Buxton91's Avatar
Oh no!!! his spelling is starting to slip again here comes the retarded alter-ego. haha
Old Jan 14, 2011 | 12:30 AM
  #68
BigTruckGuy's Avatar
^^ to the last 5 or 6 posts above
hince my pic i posted earlier
Old Jan 14, 2011 | 01:02 AM
  #69
4.2trimble's Avatar
Yes, in almost any situation the lugs snapping and shearing off would be the last thing to break.
They were severly over torqued then add the offroading to that and blam they gave up. Like i said ive done things to my truck that you probably wouldnt think of doing and have not had all the lugs shear off... I have had a lug break (1) and i credit that to me over tightening it with the impact.
(True story) After finishing my SAS i put my tires and wheels back on and came up 1 lug nut short. So i figured it would be fine and said screw it ill pick one up later. Well my stupid self let it go for about a week maybe 2 well the vibrations from the 40" tires cause that lug to back out of its hole and catch on the u-joints in the front end (crappy dodge D60 always locked so everything spins), i was traveling approxamately 45 mph. Normally you would think that he u-joint spinning at that speed would break the stud and let it fall out without much of a notice. Negative i kept hearing tapping... very very loud tapping, thought it might have been a hub going out, well then it started getting louder and i could feel it though the truck, so i started slowing down, well somewhere between 35-40 MPH the lug pushed into the spinning u-joint skidding the truck to a stop, Now think about this, thats a truck with 115 pound tires going 35-40 mph stop in its tracks (it pushed me severly left since i couldnt hold the steering wheel.) This was the only time that i ever had an a dangerous problem with the truck and it was totally my fault. So now you can see just how strong 1 lug is. They are made to do a job and be installed a certain way, if they are not installed properly they can and will break easily.
Old Jan 14, 2011 | 01:17 AM
  #70
Buxton91's Avatar
I wouldn't put it past him. haha
Old Jan 14, 2011 | 12:09 PM
  #71
Originally Posted by BigTruckGuy
o boy
No muddin. heres a list of what you should do. follow it in order
1. Trash that f'd up wheel
2. Call rimzone. tell them you need 1 new wheel of the same one you have. tell them they will need to custom drill THE NEW WHEEL THEY ARE GETTING FOR YOU to fit your bolt pattern.
3. wait on it to come in. put it on, good to go.
i just got off the phone with rimzone they told me that they cant get the rim if eagle alloy does not make it any more...
Old Jan 14, 2011 | 12:40 PM
  #72
they still make the rim just not in your bolt pattern. how many times do i have to tell you.
its probly only been discontinued in your bolt pattern not all of them
Old Jan 14, 2011 | 12:42 PM
  #73
okay well i have decided to get my new tires put on my stock rims so that i can at least have my truck to drive tell i get a new rims, even if i have to get all 4 new rims.
Old Jan 14, 2011 | 12:45 PM
  #74
no the rims itself has been discounted. so i have been told. i called eagle alloy and they told me that the rim has been discounted. now if you would like to help me on my search for a new rim that would be helpful. hope you will help.
Old Jan 14, 2011 | 12:52 PM
  #75
what is the rim called
what eagle alloy rim is it?
