Fluid change?
Old Dec 23, 2010 | 10:38 AM
DTS2001's Avatar
Fluid change?
I am going to do a service on my 01 with the 4.6 in it soon im not sure on the tranny, so my question is what kind of antifreeze and transmission fluid would you guys recomend, i put peak 50/50 in it a couple years ago when i flushed the radiator and havent done a tranny flush yet?? thanks for any advice.
Old Dec 23, 2010 | 02:25 PM
Use any name brand Mercon V fluid in the tranny and any name brand coolant except Dexcool - but do a complete flush if you are changing types of coolant. Just make sure the coolant meets Ford specs.
Old Dec 23, 2010 | 11:32 PM
buy the premium gold motorcraft coolant from the dealership, its only like 14 bucks or so. Recommended every 5y 100k
and i agree with GLC on the Merc V or better in the trans. recommended every 60k IIRC
Old Dec 24, 2010 | 03:39 AM
I'm running plain old standard Autozone green coolant. I don't expect it to last 5 years or 100k.
Old Dec 24, 2010 | 06:18 AM
Bansheeman6100's Avatar
i Use Valvoline Maxlife DEX/MERC and Prestone 50/50
Old Dec 24, 2010 | 10:23 AM
Galaxy's Avatar
Amsoil for everything...even the antifreeze!
Old Dec 24, 2010 | 10:58 AM
Red02FX4's Avatar
The trans filter does not get changed with a trans flush due to the pan not being removed. I had my trans flushed when I bought it last year, but just recently had all the under-carriage fluids changed out and replaced with synthetics
Old Dec 24, 2010 | 07:59 PM
str8t six's Avatar
i use valvoline mercon V for my trans. drop the pan and change the filter too while your doing it and clean the magnet in the pan.
Old Dec 25, 2010 | 01:58 PM
biggrey's Avatar
I use Valvoline Mercon V. Around here O'Reilys had the best price. You'll need a whole case if you drain the torque converter. An 01 should have the TC drain plug. The gasket on the trans pan is reusable, you don't need to replace it unless it is damaged.
Put 9 quarts in the trans, start the motor and shift through the gears to fill the TC and valve body, shut it off and add the last few bottles. If you skip this step the trans will overfill and you'll be wondering how trans fluid can make this big of a mess. Don't ask how I know this.
Old Dec 25, 2010 | 02:36 PM
im fixing to replace my trans and knew not til fill it up all the way the first time, but didnt know exactly how much to start with. thanks
