Another Console Build
Got the pieces from Pat today, damn near a complete console for 30 bucks and some headlight housings (no spoilers). Looks like its going to take some finagling but should be able to make it work with little modifications, going to start on it tomorrow.
Yeah, was good to shoot the breeze for a few minutes and check out your truck. I just added to the one that you have running.
After looking at BigTruckGuy's threads and a close up of his console I'm starting to think it will work easier than I expected. I'll probably have to frame the inside of the shell out of mdf or something similar just to give it some stability and build some sort of riser for the shell because the actual stealth box sits inch - inch and a half off the floor of the truck. I got to admit I'm pretty stoked and Sunday can't get here fast enough, forget Christmas
Thanks boss. Man I'm starting to feel bad for chopping the hell out of this console when all it really needs is a skeleton(one for 25+shipping on ebay) and a lid. I'll do my best to get pictures as I go but I tend to get into the task and forget to click.
Alright made some decent progress to day, pics incoming.
Mocking it up before going to the store:
After a couple hours of chopping it up with a dremel:
Mocked up in the truck, tape to hold it tight at the bottom, looks like I'll need to frame the inside to keep it tight:
Need to make a back piece since the one that I got from Pat isn't going to work, angles and stuff. Got an idea for matching the storage area up with the rest of the shell. Not sure if I want to just eliminate the entire side pocket area or glass around the speaker box. Think I'm going to have to shave some of the cushion out of the arm rests, wide top console, so it will fit right, removing it makes it look ugly.
Questions, comments, suggestions welcomed.
Last edited by My01SCrew; Dec 27, 2010 at 08:07 PM. Reason: when you leave words out stuff doesn't make sense.
looks good so far, Id probably recommend just glassing the back up once you get the sides mounted and structurally sound.
I love having the little pockets on the side of my console, and im sure youll probably want the extra storage space since you wont have much space inside the main body of the console.
