Questions on Combustion In Cooling System & Camshafts???
Old Nov 20, 2010 | 03:01 PM
Chief Mike's Avatar
I have a 1998 F-150 with a 4.6, auto. It has 112,000 miles. I just found out that I have combustion leaking into the cooling system which mean either a cracked head or blown head gasket. I am going to have the heads pulled off and have the heads checked for cracks. If they are ok then I will have a vavle job done and have them resurfaced. Being that it is a sohc motor I was wondering about changing camshafts to a rv grind (more torque) seince I tow a boat and sometimes a flatbed trailer. Will the camshaft up grade work with my trucks ecu? If it will be compatible what's a good camshaft (2) to install to increase hp & torque & a good place to purchase them? Thanks. Chief Mike.
Old Nov 20, 2010 | 03:49 PM
Veteran: Army
you might as well step up to PI heads and rebuild your bottom end since the stock rods suck
Old Nov 20, 2010 | 05:32 PM
jbrew's Avatar
So you saw bubbles in the expansion tank or degas bottle? Your referring to combustion gases correct ? lol. Or did you use a test bottle w/blue solution.
Old Nov 20, 2010 | 07:47 PM
ONELOWF's Avatar
http://www.compperformancegroupstore...de=MODFCAM2VXE
These work for stock heads and computer. They are actually worth $ 500-$550 new in the real world, less used.
Old Nov 20, 2010 | 07:59 PM
Labnerd's Avatar
^^^^^^^Exactly that Comp Cam. It's the best out there for folks wanting a little more grunt when towing and not have to fool with a programmer or chip. It will have a slight choppy idle, kinda like an old 3/4 cam, if yer old enough to know what that is. It will be the cam that goes in my 4.6 when I break it down next year. If you buy it, make sure to use their cam break-in lube or expect cam failure.
Old Nov 20, 2010 | 08:26 PM
jbrew's Avatar
Old Nov 20, 2010 | 10:19 PM
Chief Mike's Avatar
Hey Guys, Thanks for all the quick replies & advice. Are these motors roller or flat tappet? I know if it is a flat tappet I need to replace the lifters, what about if a roller? Jbrew, I used the clear test bottle with the blue solution it turned yellow (bummer) & thanks for the video clips (cool). onelowf, Thanks for the info on the camshaft, thats what I am looking for. Labnerd, Yes I am old enough to know what a 3/4 cam is & the song China Grove by the Doobie Brothers. (who) for all the young people. To the good old days! Thanks. Chief Mike
