URGENT!!--need some help guys
Old Nov 3, 2010 | 12:28 PM
thejake1989's Avatar
i searched fx4 in houston but normally just search f150
Old Nov 3, 2010 | 09:14 PM
Powers150's Avatar
im pretty sure lmc truck sells them as well
Old Nov 4, 2010 | 12:49 AM
Klitch's Avatar
Originally Posted by jbrew
Yep, I was thinking the same thing. Most Aluminum are 100' lbs. That's one thing I always use a torque wrench on, - a habit I don't wanna break.
Look at the lug nut washers, if you have washers. Ford has the torque #'s for your rims either stamped or raised on the washers.
I've heard of caliper bolts (anchor plate bolts) coming loose and tearing things up as soon as you touch the brakes. I can't recall which one, either the top bottom, - anyway, if the right one falls out while your driving and you tap the brakes, - the caliper whips around, explodes, blows out the tire plus screws the rim up beyond repair.
Glad your alright, that's no fun, -specially a steer tire.
BTW - Ebay for rim.
That'd have to be the bottom ones to create carnage, luckily I only lost the upper. still make a clunk.
Old Nov 4, 2010 | 11:10 AM
jbrew's Avatar
Okay, - it's the bottom one then. Man, I couldn't remember which one I lost lol. Must have been the top. I know it was the passenger side for sure. I was pulling a four place horse trailer back and forth, - moving last year. I wasn't real heavy, but something in the front end was making noise and getting worse. I pulled over 4 times looking for that noise maker and didn't find anything wrong, - that I could see.
The bolt finally totally fell out while on the e-way, I tapped the brakes and heard a clunk, then heard the bolt bouncing down the e-way, ting, ting ting, - I passed it lol.
I quit caring enough to stop, - I just B-lined it to headquarters.
Very lucky, no damage and I could see the problem this time, with the bolt missing. I think those are the largest bolts on the truck. Ford sells those with Thread Locker "Blue" already applied . Hardness/grade on those suckers are around 11.9 if I recall. Torque's around 160-180' lbs.
Old Nov 4, 2010 | 12:03 PM
DirtySCREW's Avatar
I want my truck back! I miss her!!!--DirtySCREW
Old Nov 4, 2010 | 10:39 PM
Klitch's Avatar
Yeah, they're suppose to be in there good
Old Nov 5, 2010 | 07:06 PM
jbrew's Avatar
You don't have it fixed yet? What's the hold up? Man you take forever
Old Nov 7, 2010 | 09:39 PM
shifty_85's Avatar
This sucks my buddys G/F just had her back left full off the lug nuts fell off and 2 studs broke on her 91 exploder....
then 2 weeks later her left front came off in traffic and hit a new escape. the wheel bearing walked off and broke the brake line took the brakes rotors and every thing the lug nuts were still tight.
I have broken studs do to over tightening but never had one break on the road. as Jbrew said 100lbs. i didnt have a TQ wrench and tryed to wing it and snaped 2. i keep about 8 in my glove box on the "What if" so there easy to change. but now i always use a TQ wrench.
Sorry to hear....ill ask my buddy he had a set of 17" expy rims 5X135 lug pattern.
Old Nov 8, 2010 | 06:41 PM
DirtySCREW's Avatar
http://cgi.ebay.com/ebaymotors/Ford-...ht_2429wt_1165
Does ANYONE know if this wheel will MATCH my wheels EXACTLY??? I have seen solid silver wheels like this...but mine have the "horseshoe" part (for lack of a better word) darkened or greyed out. I want the same. Is quality the same you think?? I'm not having luck finding anyone selling their FX4 wheels locally---DirtySCREW
Old Nov 8, 2010 | 07:43 PM
DirtySCREW's Avatar
The other alternative is:
http://www.tascaparts.com/partlocato...layCatalogid=0
---DirtySCREW
Old Nov 9, 2010 | 02:04 AM
The Ebay wheels are replicas. Tasca wheels will be genuine.
Old Nov 9, 2010 | 08:05 AM
hockeyfanjeff's Avatar
this just showed up on the classifieds on here...
https://www.f150online.com/forums/pa...lter-sale.html
Old Nov 9, 2010 | 10:30 AM
DirtySCREW's Avatar
hockey---u da man. PM was sent to that poster-----DirtySCREW
Old Nov 9, 2010 | 11:15 AM
shifty_85's Avatar
my buddy has a set of 97 expy 17" 5 on 135MM rims but it looks like you got it handled.
Old Nov 9, 2010 | 11:18 AM
your buddys expy rims have 12mm lug holes vs the 99-03 14mm lugs also
