fog lights again
Old Oct 26, 2010 | 10:05 AM
Jeff51's Avatar
fog lights again
I've searched the past threads and I found what I wanted, but the link on that thread is dead. What I need to know is how to wire the factory fog lites to a seperate switch so that I can turn them on, no matter where the headlite swtich is (on/off). Can any body help? Thanks
Old Oct 26, 2010 | 11:43 AM
thejake1989's Avatar
search bambi mod
Old Oct 26, 2010 | 12:42 PM
Jeff51's Avatar
Do I have to modify the headlite switch to get the fog lites to come on with a seperate switch. I looked at the "bambi mod" and in all of them the head lite switch is modified. Ijust want to put a seperate sw, so that I can turn the fog lites anytime I want to regardless of where the headlite switch is set at. Is this even possible?
Old Oct 26, 2010 | 12:44 PM
MGDfan's Avatar
OK - search fer recent posts by "Xtremebawls" ( yes, that's an actual Screename )
If you find it, you can glean from his discovery a very straighforward solution - you will just need to add a switch. He's done all the rest for you.
MGD
Old Oct 26, 2010 | 01:56 PM
Jeff51's Avatar
I must have missed that thread in search because I can't find where he says anything about putting in a seperate switch. Thanks
Old Oct 26, 2010 | 02:10 PM
MGDfan's Avatar
He doesn't - you do.
Originally Posted by XtremeBawls
Alright, for future reference for any of you guys who want to enable the fog lights on in every position(excluding the "O" off position) with Hi and Lo beams, splicing the yellow and brown wire will do exactly that. Doing that will remove the tedious step of pulling apart the switch and filing the ramp. The only reason i could see anyone wanting to go that route is if they wanted the ability to have the fogs on or off, if you want them on at all times then this is the fast and easy way to do it.
Replace 'splice' with 'switch'.
MGD
