alarm install
Old Oct 11, 2010 | 10:55 PM
bustamove's Avatar
alarm install
viper 350 plus
for the most part i have the alarm installed it unlocks and locks the doors and so on
but after 45 min the door triggers go off.. i researched this and was told that it cuz the GEM is going to sleep, so what i did was put a diode between the GEM and the door trigger and put the alarm tap into the door trigger side of the diode....
im using the (-) side blk/yellow i think on the driver side..
my alarm still goes off... the only thing i have done was isolate both door triggers from alarm. so i have 2 wires into one alarm door trigger alarm wire.
also how do i wake up the GEM so it unlocks the doors properly
Old Oct 11, 2010 | 11:01 PM
tre5peter's Avatar
I don't use the negative trigger. I go straight to the domelight and grab the Black with Blue positive trigger. I have never had an issue with my truck.
Old Oct 13, 2010 | 09:06 AM
slow96z's Avatar
I agree with tre5peter, the only downside to this is the domelight delay will bypass the door monitoring until the light goes off.
