Changed My Plugs - What a difference.
Old Oct 7, 2010 | 12:42 PM
galenweaver25's Avatar
Well yesterday I change all my spark plugs and coil packs and what a difference. I have an 01 S-crew with the 5.4 with 140k miles.
It took about 3 hours and was not too difficult just a lot of careful work and changing socket extensions.
The truck always ran good but there is a very noticeable difference in the idle (much smoother), acceleration and throttle response. I am sure mileage will improve but I don't track it.
I followed the direction on the forum and it all went smooth. You need lots of different extensions and I used the wobbley type extensions and not the swivel piece like some others. Removing the fuel rails made it a lot easier but now I know I need to clean my injectors after seeing them.
My engine was pretty dirty so compressed air was my friend and I blew everything out at each step.
It made such a difference I wish I would have done it long ago.
Here is a pic of my old plugs.
[IMG][/IMG]
Old Oct 7, 2010 | 01:20 PM
Nikko's Avatar
Good to hear, I'm planning on changing mine before winter sets in as well. Did you use Motorcraft as replacements?
Old Oct 7, 2010 | 07:54 PM
I did use the motorcraft.
Old Oct 7, 2010 | 10:04 PM
fishsniper's Avatar
Could you point me in the right direction of the thread on changing the plugs? I am looking at a couple of trucks on Sunday, and I think it would be good before winter.
Old Oct 8, 2010 | 11:51 AM
here is the main one but also search. Despite what this article says you DON'T want to use anti-seize and torque to 28 ft/lbs. You also want to make sure you use diaelectric grease on the boots.
http://rmftc.com/howtos/sparkplugs/sparkplugs.html
I was amazed at the difference it made.
Galen
Old Oct 8, 2010 | 04:17 PM
fishsniper's Avatar
Thanks!
