Why does everyone say no to Bosch?
Old Oct 6, 2010 | 06:27 AM
dcmband03's Avatar
I am just wondering why everybody keeps saying stick to OEM stick to OEM...what is a better after market spark plug that everybody has used? I have a 2001 4.6 XLT if you all are wondering...I just want to know some facts about why people keep pushing OEM
Old Oct 6, 2010 | 07:06 AM
MGDfan's Avatar
This is why:
"Look Ma, no electrode" !
And - if yer really unlucky:
Bottom line: OEM Motorcraft plugs are inexpensive, nickel-plated, platinum-tipped, are of the correct heat range, run excellent, and tend not to fall apart in use.
Good enough fer most folks. If ya have the burning need to spend $$$ get Denso iridiums (you'll need the IT-16's fer yer specific truck). They are probably the best there is.
MGD
Old Oct 6, 2010 | 07:10 AM
torkum's Avatar
This is why [bought this 02 5.4 from a guy that ran Bosch for less than 2k miles]
Old Oct 6, 2010 | 07:26 AM
Ford12508's Avatar
Torkum, that holes is there for extra intake whenever the engine needs it, trust me, it adds like 400HP.
Old Oct 6, 2010 | 10:28 AM
dcmband03's Avatar
gapping
Originally Posted by MGDfan
This is why:
MGD
for the iridiums i noticed they are pre gapped at .44 should they be gapped to .54?
Old Oct 6, 2010 | 10:49 AM
MGDfan's Avatar
http://www.densoiridium.com/installationguide.php
https://www.f150online.com/forums/ch...my-engine.html
https://www.f150online.com/forums/920757-post3.html
Given the above - you may want to leave it alone - they can easily be damaged while regapping if not careful ... but if you do, 0.050" is recommended (see last linky).
MGD
Old Oct 6, 2010 | 01:05 PM
dcmband03's Avatar
while im asking questions
MGD
Do you have dual exhaust if so what do you have?....or why not to get dual exhaust....i found magnaflow's online that do not require welding and it is a DIY kit but im debating buying it
Old Oct 6, 2010 | 01:46 PM
MGDfan's Avatar
Sir - you are bent on turning this into a multi-purpose thread
No - I do not have duals.
For yer exhaust question(s), may I redirect you to this for starters: https://www.f150online.com/forums/ex...duals-not.html
And, please see the sticky linked in my sig for an excellent tutorial.
IMHO - Duals can affect yer low-end if not sized correctly. Maggie catbacks are fine - be prepared for some drone in the 1800-2200 rpm region (a common experience).
Additionally - Have a look-see in the exhaust section - a few folks there know a crapload more than I do on this topic. Duals are a very popular topic.
MGD
Old Oct 6, 2010 | 02:26 PM
Halverso_99's Avatar
ive been running bosch platinum plus plugs for nearly 10K now with no problems whatsoever...
Old Oct 6, 2010 | 02:35 PM
MGDfan's Avatar
Buy a Lottery ticket. Now.
You name it, someone on here is running it.
I'll just let the preponderance of the evidence speak for itself ...
MGD
Old Oct 6, 2010 | 03:06 PM
jbrew's Avatar
Then you already have something in your head that's broken.
Old Oct 6, 2010 | 04:12 PM
MitchF150's Avatar
Good one Brew!
You all know what I'm running, but I'll not state anything else, since I don't want to get all caught up in a debate that for whatever reason has not happened to me in over 100,000 + miles...
Mitch
Old Oct 6, 2010 | 04:31 PM
shifty_85's Avatar
i ran bosch double platts for 2,000miles had a bad stumble/missfire then ran autolite double platts. for 3,000 miles had a miss. been running motorcraft single platts. not one prob in almost 20,000 miles.
oh and also because my truck tells me to.
"The more parts that say MOTORCRAFT the happyer a triton motor"-ME
Old Oct 6, 2010 | 05:27 PM
jbrew's Avatar
Originally Posted by MitchF150
Good one Brew!
Mitch
Yea, but you have stock in the company.
