f150 clicks but wont start
Old Sep 28, 2010 | 05:06 PM
hammerdown45's Avatar
I have a 2001 4.6 screw and its coil got wet. I replaced the coil and spark plug but now that its all in my truck wont start. I turn the key all the way and I hear a click but nothing else. After the click it looses all power and I have to disconnect then reconnect the battery again. I cant figure out the problem any help would be great. Thanks in advance.
Old Sep 29, 2010 | 02:15 AM
Bluegrass's Avatar
You have a corroded/loose connection in the start circuit at some point.
If your dash gages also go dead, and interior lights also go out, that is also supporting the cause of your no 'crank' issue.
Clean both battery connections and posts.
Go over the starter connections and power cablse at all point.
Good luck.
Old Sep 29, 2010 | 07:44 PM
F150man21's Avatar
dead battery?
Old Sep 30, 2010 | 03:09 AM
five0merc's Avatar
Going with the cable ends or battery.
Old Sep 30, 2010 | 11:21 AM
jbrew's Avatar
I agree, - starter posts are most likely corroded. Common problem.
Old Sep 30, 2010 | 11:30 AM
F150TX's Avatar
just did this on my parents truck. it was corroded negatvie cable end. cleaned it up and started right up
