Wheel bearing replacement
Old Sep 15, 2010 | 02:05 PM
camopaint0707's Avatar
Does anyone have any advice about changing both front wheel bearings on a 1997 4wd standard cab? Both of mine are shot and need replaced.
Old Sep 15, 2010 | 03:18 PM
beechkid's Avatar
25 Year Member
Timken brand only!
Old Sep 15, 2010 | 04:30 PM
Lightning Expo's Avatar
I would go through ford for bearings. I've seen every kind that local parts stores have and ford seems to have the best quality.
Old Sep 15, 2010 | 06:21 PM
like a ford dealer? does anyone have any advice or a how to on how to actually replace them?
Old Sep 15, 2010 | 11:10 PM
Yeah just go to a ford dealer. Not sure how to replace them on a 4wd though my truck is 2wd. Do you know how to pack the bearings?
Old Sep 16, 2010 | 04:13 AM
Klitch's Avatar
its fairly straight forward. I did mine a few years ago by removing tie-rod end at the knuckle, and the upper balljoint. Push the cv through the knuckle/hub (easiest is to unbolt it from the stub shaft on axle) then there are 3 bolts that hold the hub/bearing assembly to the knuckle. (ABS connector also)
If its too much of a fight just remove the whole knuckle.
Old Sep 17, 2010 | 11:44 AM
DirtySCREW's Avatar
Camo--I have a 03 4wd and you can't "repack" them. You just buy new ones and bolt them up as its all an assembly. I THOUGHT all 97-03s were this way but I could be wrong. Check out RockAuto.com for good prices. Hope it helps---DirtySCREW
Old Sep 17, 2010 | 12:12 PM
beechkid's Avatar
25 Year Member
Timken is who has made them for Ford, GM etc for 40+ years!
Old Sep 17, 2010 | 05:02 PM
Okay, learn something new everyday lol. Didn't know timken made them and didn't know you didn't have to pack them, figured it was similar to mine.
Old Sep 17, 2010 | 05:57 PM
RAM AIR's Avatar
Yep, definitely Timken. Get them at Auto Zone. Advanced & Napa don't carry them!
Old Sep 30, 2010 | 11:56 PM
thesnowman269's Avatar
take off the brake system from the knuckle... then use a 25mm socket ( i think going off the top of my head) unbolt the center nut. on the back of the knuckle there are 3 15mm bolts, take those out, use a gear puller, pull the bearing off. put the new one on. tighten all the bolts put the nig nut back on puit the rotor and caliper back on.....in a nut shell
