Installing Spacers
Old Sep 6, 2010 | 05:53 PM
brokenlegboy33's Avatar
Installing Spacers
I have a 97 F150 2wd and im thinking about installing spacers. How hard is it it to install them and are there any other products you would need such as steering extensions, etc. I want the truck leveled and an extra couple inches as well. Any recomendations?
Old Sep 6, 2010 | 10:02 PM
wandell's Avatar
Coilspring spacers? You remove the front coilspring and then reinstall them with the spacers and get the front end aligned. You can't go larger than a 2 inch spacer or you won't be able to get the alignment within specs without longer upper control arms. A lot of people need adjustable camber bolts to get the alignment within specs so I'd install them while you have the front end apart since they are usually less than $50 at most parts stores.
