Only 3 gallons of coolant?
I drained the radiator and block on my 02 F-150 4.6 and I only got 3 gallons out of it, it only took 3 gallons to fill up the degas tank. The manual says it has a 5 1/2 gallon capacity.
I'm flushing it with distilled water to get all the old junk out because it was nasty.
Should I put 3 gallons of 50/50 mix in, or should I assume that there is an extra 1 1/2 gallons of water somewhere in the system and add extra coolant to compensate?
There is coolant in your heater core too.
Run the truck (make sure its warmed up and the t-stat is open), turn on the heater to full blast and have someone pinch the return hose as you add 50/50 until it fills up.
That's right, I change the thermostat when I flush mine out, "cold" . As far as Capacities go -
2002-2003 4.6L Capacities/Cooling
Standard Cooling = 25 qrts.
W/aux cooling = 27.2 qrts.
where is the block drain?
What! Really? Alright, I'll check/results -
Resource #1 -
____________________________________________
Resource #2 -
_________________________________________________
Resource #3 (The one that doesn't lie. Ford Service. ) ~
Resource #1 -
Resource #2 -
No problemSo old dogs do learn new tricks
I drained the drivers side of the block. I think the pasenger side was behind the starter so I left it.
I have a 4.6 with the single row radiator. It looks like it should take 4.85 gallons.
Can there be 1 1/2 gallons in the heater core? I would expect that draining the radiator and block would empty the heater hoses and basically everything except for the heater core.
biggrey - I drain the rad, then the block. I don't have two block plugs, just one on the drivers side. I've pulled the starter and wire wheeled the passenger side of the block looking for it, - doesn't exist. Anyway, I pop the thermostat and that's when I get more from the block. Then pull your heater core line for the rest. Then flush from the highest point. I purge the air from the core line as well. Sometimes it's a chore getting air out of these systems, but you need to, this avoids hot spots and gurgling effects after your thru.
Some have posted that they refill from the degas bottle and all is fine. I've tried that quite a few times and used the factory bleed and burp procedure only to still have air in the system as a result. Good luck with that, - if worse comes to worse, you can always pull from the highest point and purge the rest.
Today I pulled the heater hose and it was empty, so I'm getting the water out of there. I'm trying to flush the system several times this week to try and get all of the old junk out.
